1975 F100 4.9 build. Carburetor opinions - Page 2 - Ford Truck Enthusiasts Forums
Old 12-20-2017, 08:05 AM
drewduncan15's Avatar
drewduncan15
drewduncan15 is offline
drewduncan15 is gaining momentum as a positive member of FTE.
Just bought a new Radiator. https://www.ebay.com/itm/1968-1979-F...RZFdxV&vxp=mtr
Picked up a junk yard front core support. My original one had a little bit of rust in the one corner. The new one is a galvanized one with the larger radiator opening. This radiator will fit in there nice and the inlet and outlet should be close to right. should easily cool that 300.
Old 12-20-2017, 08:34 AM
The Frenchtown Flyer's Avatar
The Frenchtown Flyer is offline
The Frenchtown Flyer is gaining momentum as a positive member of FTE.
Plug up any gaps between the radiator and the core support if the core does not fill it fully.
Old 12-20-2017, 08:39 AM
drewduncan15
Right, After measuring last night it should fit right in. Going to put electric fans on it. Not sure if i should just buy some online or try to find a good one out of a junk yard. Know a lot of people use the Taurus Fans. And their alternator. haven't found a 92-94? Taurus to pull it from. Found the alternator new for around $70 but doesn't come with any of the wiring harness. Need to look again tho. Any suggestions appreciated.
Old 12-27-2017, 10:17 AM
drewduncan15
Ive ordered just about all the necessary parts for my Holley Sniper 2300 swap. Doing some underbody painting prior to starting in on the motor. Picked up a 130amp alternator and need to go back for the Taurus electric fan.
How do you like my bed lift.
Old 12-31-2017, 02:15 PM
Originally Posted by drewduncan15 View Post
How do you like my bed lift?[/left][/left]
I liked it so much we now have one in our bedroom.
Old 12-31-2017, 03:18 PM
fordman75
fordman75 is offline
fordman75 is a name known to allfordman75 is a name known to allfordman75 is a name known to allfordman75 is a name known to allfordman75 is a name known to allfordman75 is a name known to all
Just one suggestion. If you don't have one, install some kind of spreader bar ( Or a tailgate ) at the rear of the box. I have seen the bedsides buckle in on a couple trucks lifting the box that way. Something to keep bedsides properly spaced in the back is just some cheap insurance.
Old 12-31-2017, 04:39 PM
drewduncan15
Good point! Itís a very solid bed. But I just went over and lowered it down on some tires. Want to flip it over when I can get the help.
Old 02-26-2018, 07:50 AM
drewduncan15
Question:
Took the truck on a short test drive yesterday. Sniper ran great. At 60 mph I was running 2300 RPMs. I've been considering changing my tires to something slightly bigger. It currently has 235/75r15 on it. Thinking about Firestone Destination 30/9.5r15's.
Truch has a C4 and 3.0 gearing.
So with mpg in consideration would increasing the tire size to lower rpms improve my fuel consumption with the added weight of the larger tires?
the 235's are @ 29lbs - measure at 28" on the truck
the 30's are @ 35lbs. I know rolling weight plays a big factor in mpg.
Old 02-27-2018, 04:29 PM
I am of the opinion that the increased inertia and rolling resistance, increased aerodynamic drag, increased intake manifold pressure and reduced braking capability will more than offset any fuel economy benefits from the reduced rpm.
StanOostenga
13
11-10-2015 10:17 PM
naughtynorthwest
02-13-2015 04:49 PM
veetwelve
07-14-2011 11:56 PM
kalsong
13
12-07-2009 03:13 PM
76shortbed
03-02-2009 08:55 PM
Quick Reply: 1975 F100 4.9 build. Carburetor opinions
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
