1 Rear wheel locking up when braking?
It has been an issue since I bought the truck, but it isn't my DD so I eventually replaced all the hardware shoes and drum. Still did it. Took it into a Ford Dealership and they said it is the ABS Hydro Control Unit? Part # 3L3Z 2C286 AARM Supposedly an internal valve is sticking.
When I pull up this part number, it shows that it is the ABS HCU unit for a Ford van? I have toyed with the idea of just pulling the ABS fuse and seeing what happens.
I want to buy another one (it would have to be used since apparently this part isnt made anymore?) but other than a bone yard have no idea where to pick one up. I would rather purchase one that was probably going to work vs. a bone yard one that might have the same issue... Or maybe this is a one off?
Thanks for your help.
If they are reading a CODE which tells them the ABS unit is bad... OK........ if they are guessing , I would verify correction operation on both sides.
You should be sure ALL parts on the rear are functioning correctly... There is NO WAY for the ABS to apply ONE rear brake and not the other.. Either they BOTH are trying to engage, or there is a mechanical drag at one rear wheel.
I agree, both should be trying to lock up... but just one does. There was no ABS code for them to read and the light on the dash is functioning properly. Should I take it to another Ford dealership for a second opinion? I've checked for pinched lines, replaced all the hardware.... twice. I am kind of at a loss where to move to troubleshoot now.
I appreciate your response!
Are the original brake hoses still on it?
There have been occasions where one of the front hoses on the brakes became delaminated inside and a check valve formed.. You can apply the brake, but it will not let the fluid back out to retract...... that's why PDQ asked about the hose. rare, but does happen.. normally it makes the brake NOT BACK OFF when released.
Did you replace all the hardware, shoes, and drum on both sides? I'm assuming you did but your initial post indicates possibly just one side. I have 97 and have had this same problem off and on for the last 20 years of owning it. With 200k on it I've replaced the rear brakes 5 or 6 times and I can say that some brands/quality of shoes have caused this problem with me. Replace with something else (brand) and could go literally years without issue. Just something to think about....
When I left off the brake, it unlocks and the wheel keeps rolling so I am thinking the one way check valve hose idea might be out... And yes I have tried more expensive shoes in addition to changing out both side at the same time.
I was pulling in the driveway the other day in my other car and the headlights shined on the inside of that wheel and there is seepage of brake fluid on it. Annoying.
I appropriate all the help so far, thank you.
79shovelhead
10-16-2009 04:42 PM
351whitewindsor
1999 to 2016 Super Duty
08-09-2009 11:21 PM
89MustangGX
06-10-2004 12:03 AM
