Misfire cyl 5, fixed/not fixed
#61
#62
Those look nice and offer best warranty. These are the ones I came up with, little cheaper but the warranty sucks compared to yours:
https://www.ebay.com/itm/SET-of-10-D...53.m2749.l2649
#63
The notch for the locking tab is too small on these coils so the connectors do not snap and lock when installed. I decided to use zip ties to ensure secure connections. After 500 miles, 2 of these coils began to fail after reaching operating temp. I was able to get them replaced for free under warranty. We shall see how long the rest of them last. For the price I may buy another set just to keep as run away spares!"
You should feel right at home. The solution for your misfire will reveal something interesting I'm sure. Good Luck!
#64
I hope you do something soon. Here's a comment on one of the recommended set of coils,"Not OE form factor but still a bargain!
“You should feel right at home”?
#65
#66
Ok I understand now. I believe I’ve already addressed you about typed sarcasm. It should be openly and clearly sarcastic, and it should be clearly identifiable as humor or malicious. Yours failed both tests.
#68
Does the guy who sold you the new van still have the 2nd one? How about just buying the other one and putting a bullet in the V10 after taking off the tires? As I recall, you had other problems with it also, and assuming you're paying for your own gas now, you may save the whole price of the 2nd van in a couple years...
In my book, time is money, and it sure seems like you could be spending your time doing actual work instead of nursing along a dying old van...
Happy New Year,
George
Happy New Year,
George
#69
#71
#72
Oh please, it's always best to actually determine the failure point and spend $'s only on that than to just replace all 10 *****-nilly.
My 2001 V10, around 60K miles, but lots of high-temp idling/pulling whole trees in Upstate NY and on Long Island in 90+ degree heat, and no coil failures.
#73
#74
And now that I own 18 cylinders' worth of these coils, I will almost certainly try the whole set of cheap coils.
for sake of accuracy though; I received mixed signals. At one point the misfire did not follow the coil. But then most recently it did.
it's a mystery.
#75
