just joining the club!
I recently purchased a 2005 excursion xlt 5.4 that has been sitting for over a year. I replaced the battery and alternater and it fired right up but has a miss and some light smoking. Also some electrical issues dash lights are out and rear riding lights were out. I replaced the bulbs and exterior lights fuse and now they are working. There was some burnt places on the break light socket. Looking for advice on what to do next. what should be included in the tune up to start?
If it's white smoke for just a minute or so after startup it's probably just water vapor.
For the missing you might just need a new set of plugs and boots.
How many miles?
An OBD2 port bluetooth adapter and software like Forscan will help isolate which cylinder is misfiring.
Check the vacuum hoses for soft spots, particularly the PCV line elbow near the throttle body.
My tail light sockets are brown from heat, too.
I tried switching the turn signals to LED bulbs, but the turn signal flasher didn't like it.
Tried the electronic relay style flasher and it didn't work, either.
Last edited by R&T Babich; 12-16-2017 at 10:59 AM. Reason: Changed "mechanical" to "electronic relay", not the OEM bi-metal type.
Welcome to the EX forum and family!
Now we need pictures!
Run a scan for codes and misfires, then 8 new boots and plugs would be my first step. If the miss continues swap the identified bad COP to another cylinder and see if the miss travel with it, if so get a new Denso COP to replace it.
Tell us more about the smoke.........white, blue, black........only when cold, on startup, always, on deceleration.....
Is it RWD or 4X4?
Is it RWD or 4X4?
What size resistors and does each bulb get one?
I was trying to avoid this technique because it negates the reduced current load benefit of using LEDs, but it's not a lot of current and it's intermittent.
It's a bit frustrating because the 2003 Exped took the LED bulbs with the mechanical flasher and works fine.
The Excur and Exped circuits are different from the voltages I see at the flasher.
You can simply but what's on the shelf, like 6ohm 50 watt, sold in packs of 2, one for each tail light. Yes you are basically returning current draw you removed when you installed the led bulbs, unless you have a can bus system that recognizes the LED, this is the only way to go. You will at least get the benefit of a long lasting and bright light source.
http://www.putco.com/documents/ResistorInstruct.pdf
https://www.amazon.com/dp/B01A77U122/ref=asc_df_B01A77U1225300985/?tag=hyprod-20&creative=395009&creativeASIN=B01A77U122&linkCode=df0&hvadid=198100799464&hvpos=1o2&hvnetw=g&hvrand=17356278971402408359&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9010685&hvtargid=pla-385274078861
Bigger problems!
thanks for the feed back and advice. The smoke is white and stops after a short drive. But now I have a bigger problem after replacing the brake light bulbs and fuse. I went out this morning and now none of the exterior or dash lights are working. Everything was working fine last start up so Im really at a lost here.
It's not a question of where they are grounded in the diagrams/from the factory. You likely have a grounding situation where there should not be one. This is causing the voltage to be "sucked" back to the battery without a load (bulb) and thus tripping the fuse protection to keep stuff from catching fire or melting.
Gotta check the fuses first. It could also be an open circuit where NO voltage/current is flowing at all vs the above too-much-current hypothesis.
