Complaint Filed with NHTSA -- Lippert Front Levelers - leaking
Old 12-12-2017, 08:25 AM
Bigdon68's Avatar
Bigdon68
Bigdon68 is offline
Yesterday I filed a complaint with the National Highway Traffic Safety Administration about the defective LIPPERT front levelers on my unit and DRV units in general. My situation was that the levelers were leaking down while going down the road causing a real concern for our safety while driving and safety in general.
I would encourage anyone with similar situations where the front Levelers are leaking down -- on the road or not -- to go to the NHTSA website and report your problem. Here is the site information:
The link is www.https://www.nhtsa.gov/
Then click on the box --- report a problem.
Anyone with leveler problems should jump on board.
Thanks
bigdon68
Old 12-12-2017, 09:08 AM
Sous's Avatar
Sous
Sous is online now
Received 4,460 Likes on 2,850 Posts
Wow, that is a big concern. By leak down, are you saying the fluid is leaking and dripping onto the surface which would potentially get onto the tires, or are you saying the actual legs are leaking down/lowering and getting closer to the ground as you drive along?
Old 12-12-2017, 11:01 AM
69cj's Avatar
69cj
69cj is offline
I interpreted it as the legs dropping down creating a major hazard on the road.
Old 12-12-2017, 11:10 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Chuck's First Ford is offline
if the legs are not staying in there "UP" location and (lowering) Moving downward onto the road ...
that would be very dangerous....
Old 12-12-2017, 11:30 AM
Sous's Avatar
Sous
Sous is online now
I am not a hydraulic expert in anyway, but would the leak down of the gear be an indication of air or moisture (water) in the system somewhere? I agree 100% that this is very dangerous and could be life threatening.
Old 12-12-2017, 11:36 AM
Bigdon68's Avatar
Bigdon68
Bigdon68 is offline
Yes the legs are leaking down
Yes, the legs are leaking down and it is very scary going down the road. This is a known problem with DRV owners. Some have been fixed by LIPPERT, in and out of warranty, now all of a sudden they are refusing to fix the problem. It is a safety issue and someone needs to step up.
There are many other LIPPERT levelers on RV rigs across the country. If they are having similar problems they need to go to the NHTSA website and report their problem. If we RV'ers stick together then things will get done.
bigdon68
Old 12-12-2017, 03:47 PM
P.Bronner's Avatar
P.Bronner
P.Bronner is offline
Lippert = crap. No news there. I've had to weld/gusset their flimsy frames after finding cracks around the spring hangers. They basically own the industry, and they're killing it with their ****-poor engineering and QC.
Old 12-13-2017, 05:42 AM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
could you use some tie downs as a temp measure for safety?
I agree, these safety issues should be reported.
Old 12-19-2017, 08:13 AM
rwtdct's Avatar
rwtdct
rwtdct is offline
[QUOTE=P.Bronner;17652585]Lippert = crap. No news there. I've had to weld/gusset their flimsy frames after finding cracks around the spring hangers. They basically own the industry, and they're killing it with their ****-poor engineering and QC.[/QUOTE
X2..............Been there, done that.
Dirt-Road-Kid97
Oil & Lubrication
01-20-2014 01:00 AM
DCFord
16
03-07-2010 02:35 PM
toolman617
08-05-2005 03:22 PM
Frank Kistner Sr.
07-05-2003 08:45 AM
Quick Reply: Complaint Filed with NHTSA -- Lippert Front Levelers - leaking
