Screwed up lifted truck
So This is my 17' Super Duty with 8" BDS Long Arm Kit. First drive in the truck after modification and I get a vibration
at about 65 is is very noticable on acceleration. Not sure what to do. Hard to diagnose from pics only I know but
any help is very much appreciated.
on
It looks like your driveshaft has been pulled out a bit [by the black ring I see] and the angles at the u-joint look a bit aggressive! I am guessing you will need a CV joint installed where the t-case u-joint is. This will also lengthen the shaft. The lift kit guys don't always disclose all the other mods a guy may have to do to make your system work! The rear of mine has been lifted 3" and I have a vibration now but luckily it is at low speed.
I'd get a custom made driveshaft that makes up for the lift at a minimum. Maybe have the tires double checked for balance. Double check the front end, double check torque on all bolts and as mentioned above find a better shop, a BDS lift shouldn't give you issues and more importantly a shop that cares will exhaust all options to remedy the issue not brush you off and just say hey its a lift what'd you expect ... on a side note I'd sure like to see some pics of that monster
