HP & torque with a trans. PTO provision
I’m narrowing my search and thought I had decided on one of two different F250 Larriet 6.2 gassers with CCSB until I stumbled upon a F350 XLT with a diesel.
This XLT has my must have center console which I’ve had a hard time finding. It has other check-offs on my list plus something I haven’t incountered up until now. A transmission power take off provision (PTO).
Now since discovering this truck I’ve done some research, a lot on this site. I’m digging the thought of an addition like this thinking it could help resale value and who knows, I might even use it. I’m just not too familiar with this add-on other than what it does. This site made that clear - thank you.
My questions;
Does the PTO affect the transmission negatively or positively?
Is this transmission built different?
Does it affect horse power or torque?
Is it okay if I never use it and is there maitanence involved if I don’t?
I guess those are the main questions for me.
Thank you
<acronym title="Page Ranking">pr</acronym>
My questions;
Thank you
My questions;
Neither
Yes, access plate and immediate gearing behind torque converter.
Yes, but not noticeably. All you have is a tiny bit of extra mass that is also rotating.
Yes. No.
Thank you
<acronym title="Page Ranking"><acronym title="Page Ranking">pr</acronym></acronym>
My questions;
Neither
Yes. No.
Thank you
The only drawback to having a PTO provision when you don't need it is that they add it to the cost of the truck. After that you don't need to do anything. There isn't actually a PTO on the truck, the trans just has the provision to mount one. It wouldn't be a negative, or even a positive over the life of the truck.
This is a relatively rare option on a pickup. It is cheap and kind of cool, but what would you use it for?
The PTO provision does not change horsepower or torque rating, and does not change the transmission, either. It is exactly the same transmission with a little plate bolted on to the side that would allow you to purchase and install a PTO which bolts in place of the plate.
It’s an option on a XLT F350 that I’m looking at.
Uses could be Hydraulic pump for a hydraulic lift (tilt box for example), hydraulic pump for snow plow cylinders (raise, lower, angle, vee formation, a small electric generator, maybe even an AC pump for a commercial refrigeration unit on the truck, Air compressor for large air tools, such as a tire shop truck...
Now to decide, XLT Diesel F350 vs. Larriet Gasser F250. Leaning towards the Diesel with the included PTO.
