Help with aftermarket headlight conections..
I've tried "search" and all the results come up for HID, and LED. Nothing for what these are.
The lights I got are for regular bulbs, but have a row of LED DRLs between the sections. The assemblies are SPEC-D brand. They look like nice quality for the money- $108. The link to what I have is below.
www.ebay.com/itm/Ford-99-04-F250-F350-Superduty-00-04-Excursion-Clear-LED-1PC-Style-Headlights/362137323438?ssPageName=STRK%3AMEBIDX%3AIT&_trksid =p2057872.m2749.l2649
They come with a loose pigtail and there are 2 wires with a flat plug (that looks like the 198 style bulb plug) that comes out of the housing .
The only instructions I can find are on the SPEC-D website, and of course... they suck. There's nothing I can find for these specific assemblies. So the question is how to get the LED running lights to work, and does the little flat plug go into the side marker?
Did your housing fit properly?
It doesn't seem that the housing is fitting right. With both of the upper studs/adjusters in, and the lower inner screw snugged in, it leaves the lower outer screw mount on the housing sticking out about 5/16" from where it should be.... something just doesn't seem right. This should be easy...
It got dark on me but I will work on it some more in the morning.
imq707s
1999 to 2016 Super Duty
24
11-15-2018 09:33 PM
wuttrd
48
04-26-2010 10:25 AM
