1955 ford military 4x4
I'm looking for anyone who may be able to identify the rears on my 55 truck.I need wheel cylinders and new dust boots.I don't know where to begin to look because I cannot ID the rears.I looked all over the truck and see no tags. I bought it off of a guy right off a military base and it does not look anything like a homade job. Surely looks to be an original conversion as the guy told me it was.
Thx
Thx
First, welcome to the group. A 1955 Ford 4x4 of which model? A half ton could have different axles and manufacturers, perhaps Dana or Coleman, than will a 3/4 or larger model that could have axles made by Timken, Coleman, Eaton, or Dana. If you’ve looked and found no tags do you see holes where tags were previously mounted inside or outside? If no holes or tags it would probably rule out the truck being a Marmon-Herrington conversion. But it could still be a Coleman, Fabco, Napco, or since it’s a 1955, one of a small group we’ve seen that have WWII military surplus running gear but were pretty clearly professionally converted as a group by an unknown company back then. As said, pictures and more description will help us help you. Stu
Thx
Thx
hope I did it right. I think I figured it out.
This is a cool Truck. Sorry I can't help you with your questions but I'm trying to learn too! One way to follow is to post a comment on your thread, get notification, and hang on for the ride. Now that you posted pictures there should be lot's of reactions. Good luck with you project. Looks fun.....and $$$$$.
you have Eaton axles from a WW2 IHC M-1-4 or M-2-4. The rear was a standard rearend from the prewar IHC K3 tonner. The front was cast special for the war. It was made to accept the rear third member. The cylinders are wagner lockheed. You can or could get kits from napa. The rear is stepped so you have to get two kits. See if they have a parts BOOK that covers K3s or K3. The transfer case looks to be a single speed NP from a WW2 Dodge. The IHC case was large and mounted with two large flat steel plates.
The M-1-4 was a 1/2 ton and tbe M-2-4 was a tonner. Only difference was 12" longer wb a d extra leaves in spring pack.
Here’s the prior discussion about your truck. The one I had the email exchange about is a different truck. Your axles look to me to be Eatons, but I’ll defer to others who may be better at identifying military stuff. Your wheels are clearly combat rims, military only, and are mounted to military spec hubs having a 5 x 6 7/8” bolt pattern. Here’s the old discussion. Edit - 1952henry and I were typing at the same time.
https://www.ford-trucks.com/forums/1...-for-sale.html
On the other truck in the email chain I recall referring the owner to Vintage Power Wagons in Fairfield, IA, for parts and help nailing down the donor vehicle. They are the primary supplier of new and used Power Wagon parts. Stu
https://www.vintagepowerwagons.com/online-parts-catalog
55 4x4
I don't think I can rebuild the wheel cylinders. They are rusted solid and pitted horribly. The boots in front need to be replaced and I would love tomake a spare tire if possible. Also worrying about what I'll do if one day I need brake drums. Who would I deal with for parts for something like this?
Will none of those work? If not I would give them a call. The Dodge military vehicles are a favorite with many collectors. They have a place to request rare or hard to find parts on that website.
Also eBay has a selector and seems to have a lot of wheel cylinders. eBay wheel cylinders for 1943 Dodge Truck axles
