Oil Pump Rebuild Kit
The Melling kit will be for the gerotor pump (aluminum housing, flat cover). If you have one of those, then yes, you can replace the rotors while leaving the pump on the engine. However, to do it properly, clean the pump check for wear and check clearances will be just about impossible.
I wouldn't replace them without reason, though. Are you having a problem with the pump?
Connecticut Calvin
09-19-2017 10:31 AM
63' f100
26
04-07-2011 11:47 AM
cdherman
11-06-2003 07:52 PM
