1966 F100 240 I6 T5 transmission?
Old 12-07-2017, 05:52 PM
Murphy1966's Avatar
Murphy1966
Murphy1966 is offline
Murphy1966 is starting off with a positive reputation.
Hello I am going to be building my new inline six (240ci) in my 66 F100 probably gonna be running a cam, headers, 2 barrel carb and an intake. Getting these parts from Clifford or Summit. I was told I cannot run my ford AOD” automatic overdrive metric” transmission with an aftermarket carb because of kickdown linkages. However this is ok I now have to figure out what tranny I want to run I definitely want a manual transmission and was looking at T5 transmissions any thoughts or ideas any details on how difficult this might be? I already have a manual transmission pedal assembly. My truck was originally equipped with a 3 speed on The collum. What tranny swap would be the easiest and best for a daily driver? And would work with the 240 inline 6?
Old 12-09-2017, 11:06 PM
ID Scrounger's Avatar
ID Scrounger
ID Scrounger is offline
ID Scrounger is starting off with a positive reputation.
​​​​​​The T5 is a hydraulic clutch and that can complicate the clutch linkage assembly/swap since our trucks never had one.
I don't see why you can't run an AOD with an aftermarket carb, the fox body guys do it all the time. You just use a Lokar cable:
https://www.speedwaymotors.com/Lokar-KD-2AODHT-Ford-AOD-Stainless-Steel-Kickdown-Cable,64967.html?sku=4912351&utm_medium=CSEGoogle& utm_source=CSE&utm_campaign=CSEGOOGLE&gclid=EAIaIQ obChMIndj9xNP-1wIVCNVkCh3dFgMBEAQYBSABEgJH0fD_BwE
An SROD transmission could be an option too if you're after overdrive. I had one in an 80 F100 with the 300 six and grew to like it. I believe there is an overdrive 4 speed toploader variant too.
Old 12-09-2017, 11:26 PM
SuperSabre's Avatar
SuperSabre
SuperSabre is offline
SuperSabre is gaining momentum as a positive member of FTE.SuperSabre is gaining momentum as a positive member of FTE.
I may be wrong, but I thought the bellhousing for the 240/300 was the same as for the 302/351 V8, and would therefore work with the T-5 transmission. I can say for sure that a T-5 installation will work with the old style mechanical bellcrank clutch linkage similar to what came in your '66 F100 because both my '64 Falcon and '66 Mustang, both with T-5s, have exactly that. No doubt a hydraulic slave cylinder clutch linkage would be easier and smoother, but I don't find it too hard. Good luck!
Old 12-09-2017, 11:34 PM
85e150
85e150 is offline
85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation85e150 has a superb reputation
T5 = conventional trans, bolts to a bell housing, use whatever clutch you want.
M5OD, the 5 speed OD Ford used in later F150s = integral bell, juice clutch the only flavor.
For the OP: You may find OD a bit tall with the T5, as well as reverse. Your rear axle ratio will be the key to happiness with that trans. 4.10s are a good ratio. Easy pulling in the first 4, OD handles the high speeds. Serving suggestion, good luck with it!
Old 12-10-2017, 07:19 AM
jowilker's Avatar
jowilker
jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Murphy, I might suggest looking at a mid 90s F150 I-6 - AOD setup for your truck.
But if I were starting new, I would look hard at a current EcoBoost auto setup for the best of the best.
John
Spncking
12-28-2013 03:24 PM
Ryan Durbin
01-22-2013 05:54 PM
vrsc04
07-18-2011 11:37 PM
fletch
02-19-2004 05:29 PM
Aekisu
07-06-2003 06:11 PM
Quick Reply: 1966 F100 240 I6 T5 transmission?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
