97 F350 7.5 driveabilty issues. - Ford Truck Enthusiasts Forums
Old 12-07-2017, 04:14 PM
masterbeavis's Avatar
masterbeavis masterbeavis is offline
masterbeavis has a very good reputation on FTE.masterbeavis has a very good reputation on FTE.masterbeavis has a very good reputation on FTE.
Codes:
P1744
P0443
P0174
P1131
P1151
P0171
I’ve checked for vacuum leaks, replaced the EGR valve, (it was letting smoke out of the valve during the smoke test) and have checked my fuel pressure(33+ while running.) The truck is acting like it is running out of gas after three-quarter throttle, will stall and backfire when it is cold from a stop, and will decelerate if it downshifts to pass/maintain speed.
Retired U-haul box truck, 7.5 mass air, 155K.
I don’t want to start throwing parts at this before I get an idea what the problem is.
the torque converter solenoid issue I’m aware of, and am dealing with that as soon as the motor is squared away.
New codes after codes cleared while changing battery
P0401
P0171
P0174
Old 12-07-2017, 05:17 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Idle fuel pressure should be 30-35 PSI. Under load the fuel pressure should rise to ~40PSI. Your listed 33+ PSI under load is too low.
Old 12-07-2017, 07:28 PM
Quote:
I may have mis quoted what I have for pressure. At idle itís 30ish, rev the motor, pressure increases to 40ish psi. I donít have the means to test while driving.
Old 12-07-2017, 07:45 PM
95fiveoh 95fiveoh is offline
95fiveoh is starting off with a positive reputation.
Is your alternator charging? What is the voltage while running? Low voltage can cause all kinds of problems.
5.4 3v P0171 and p0174 lockburner2000 1999 to 2016 Super Duty 10 05-04-2017 12:07 PM
Need help with codes/repairs 96 F150 4.9 jmccracken1214 1987 - 1996 F150 & Larger F-Series Trucks 4 09-21-2016 08:50 PM
Check Engine light p0174 p0171 Benjamin Silva 1987 - 1996 F150 & Larger F-Series Trucks 1 04-30-2016 10:00 AM
2000 f150 4.2 need help P0171, P0174 allvol 1997 - 2003 F150 4 04-02-2016 02:39 PM
intermit. rough idle, check engine w/ P0171 & P0174 codes hhoelsc 1997-2006 Expedition & Navigator 152 04-01-2016 10:26 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
