Is it possible to find a f250 or f350 with the 460
400 HP is basically a stock rebuild on a 460, but bringing compression up to appropriate levels. You shouldn't expect horrible MPG either, mid teens is what you should expect with such a mild build. For what it's worth my 460 is more torquey and accelerates quicker towing than my 6.9 diesel with turbo. The 460 also holds speed fine up grades while the diesel can't hold speed (EGT reasons primarily, an intercooler would help a lot).
If I wanted to build a fun project, I would find me a shortbed f150. Drop the 460 in that. It will be the lightest truck you can start with. Build a 454SS Ford style. Put a 9 inch in the back with 3.73 or 4.10's and a c6. Very simple and bullet proof setup.
Just in from the department of obscure information:
One time on full-size bronco.com there was a thread where somebody did a 460 swap and they notched the frame rail. I think for the headers.
Edit: found it
http://www.fullsizebronco.com/forum/.../146180?page=1
Edit: found it
That is the standard procedure when swapping 460 into a truck frame that did not come with the "dent" in the crossmember for the oil filter. I think I am right in saying even if you have the "dent" you still need a specific oil filter adapter for the 460 to clear the "dent".
See my fun truck is one that handles and with a heavy BBF (460) up front I cant see that happening.
Look at the old Mustangs that had BB motors. Great going straight but try and make a turn and it still went straight.
A 302 w/351 heads or a 351 I think would be a good match for a fun truck.
I don't think it would be that hard for 400 hp from a 351.
Dave ----
Dave ----
Dave ----
Dave ----
I bought this 1983 one owner 99,000 original mile, 22 factory options, original paint, original 460 4x4 manual trans F250 for 2k from the second owner in Sacramento CA. It had a blown head gasket and was parked for 15 years before I snagged it. Motor rusted and locked up. Brought it back to Ohio and rebuilt the engine. Not a single speck of rust on it.
They are out there. You just have to look.
Whatever year you like, whatever year you happen to come across.
454= Big block Chevy engine.....460=Big block Ford engine
454SS=special edition shortbed Chevy truck with a big engine.....Your truck would be a duplicate of this but Ford style=Ford shortbed truck with a big engine. Put "460SVO" on the side of it and get people talking.
liftedwhitef150
07-12-2022 08:49 AM
SCFlareside
03-10-2018 05:41 PM
Redleg1973
03-04-2011 05:44 AM
