Hi
I've checked all the fuses and replaced he ep27 relay and still have nothing coming on. It seemed to just stop working yesterday and not sure why but I have no directional or hazArds.
Tilt the steering wheel radically while you have the signals on and see if they try to work. If they do, there is a wiring harness plug that has too much strain on it up inside the column.
Check the flasher relay ground circuit, it's the only thing that can take out both functions simultaneously.
For it to be the wiring harness in the column would required two connections to have failed simultaneously, an unlikely (but not impossible) occurrence.
