Synthetic oil, regular oil - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 12-07-2017, 07:53 AM
Lawnpro979's Avatar
Lawnpro979 Lawnpro979 is offline
Lawnpro979 is starting off with a positive reputation.
Has anyone changed to synthetic oil, then got oil leaks, and then went back to regular oil?
i changed over and was wondering if the oil leak will stop. After changing back?
Thanks
Old 12-07-2017, 08:25 AM
speakerfritz's Avatar
speakerfritz speakerfritz is online now
speakerfritz is gaining momentum as a positive member of FTE.speakerfritz is gaining momentum as a positive member of FTE.
Thanks
yes, synthetic oil cleans out your engine sludge and if you have seal leaks, this will result in leaks sine the sludge is gone.
going back to regular oil will help restore the sludge and if you have seal leaks, the sludge will stop up the leak.
this is a masking effect. the oil is not the cause of the leak....bad seals are.
Old 12-07-2017, 08:43 AM
Chuck's First Ford Chuck's First Ford is offline
Chuck's First Ford has a good reputation on FTE.Chuck's First Ford has a good reputation on FTE.
this is SO 1970's..... an continues...
Education is key.
Chrome muffler bearings... continues. or is it blinker fluid
Speakerfritz is Correct.
and to add. synthetic has the ability to get into small places.. for better lubrication. .. my opinion.
so more leaks to tired engines.
FYI, synthetic oil was developed during world war 2 (II).... went into general production about 1950......
I have been using it since 1974...
Old 12-07-2017, 04:51 PM
Lawnpro979's Avatar
Quote:
Education is key.
WOW! I wish I were like you!
Old 12-07-2017, 04:58 PM
WHY??? I am OLD.... but not slow..
Old 12-08-2017, 12:28 AM
droldsmorland's Avatar
droldsmorland droldsmorland is offline
droldsmorland has a good reputation on FTE.droldsmorland has a good reputation on FTE.
To answer the OPs question. Its likely that the leak will slow or stop by switching back. If you have a high mileage engine then it's possible that both lubricants will leak. The leak simply wasn't as prevalent on regular oil.
Dinosaur juice has a much larger molecular structure over synthetic oil. Synthetic will leak where dino didn't simply because the smaller molecules allow it to slip past seals which were broken in on dino juice. What I mean by this is if an engine started life on dino juice and is fairly well "seasoned" and then synthetic is added, chances are really good it will leak past seals, rings etc...just as the OP is experiencing. If an engine starts life with synth then you are ok. You are not going to hurt anything from an incompatibility standpoint between the two lubricants. You will just burn and drip a lot of synthetic oil which is money down the drain and storm sewers. If you're trying to achieve the protection synthetic offers try adding ProLong to the dino oil. If your trying to extend your oil change intervals to rival synthetics consider a semi-synthetic blend, with ProLong and changing your oil per an oil analysis. The semi blend may have enough fat to not leak?
Old 12-08-2017, 06:50 AM
CollinsCD's Avatar
CollinsCD CollinsCD is offline
CollinsCD has a good reputation on FTE.CollinsCD has a good reputation on FTE.CollinsCD has a good reputation on FTE.
This happened to me on my old Ford 8N tractor. Switched the gear fluid over to better synthetic oil and developed leaks at the axle bearings. Went back to dino oil and leaks stopped. The real fix would be to replace seals but I'm too lazy to tear down this tractor.
Old 12-08-2017, 09:49 AM
bleeds blue's Avatar
bleeds blue bleeds blue is offline
bleeds blue is starting off with a positive reputation.
I have switched from dino to synthetic in my last three trucks. All with over 100k on them. Not a single leak. Im not saying it doesnt happen, just never had a problem with it myself.
Old 12-12-2017, 02:42 PM
Chuck-B's Avatar
Chuck-B Chuck-B is offline
Chuck-B is starting off with a positive reputation.
I was a hard head about synthetic oil being man made crap until I educated myself, now I wouldn't use anything but. The molecules in organic oil are all different shapes and sizes. As organic oil ages the smaller molecules tend to break down (and create sludge) thus increasing the space between the molecules resulting in a breakdown in protection. There is no protection in the spaces between the molecules and you're metal on metal. Now of course this is on a microscopic level, but over 300,000 miles it takes its toll. Because synthetic oil is man made, all the molecules are the same shape and size. They also don't break down as fast thus reducing sludge and probably why your oil leak came back. If it were me, I would get the leak fixed and use synthetic oil.
Old 12-12-2017, 06:59 PM
geekwithoutacause geekwithoutacause is offline
geekwithoutacause is starting off with a positive reputation.
mmm, where is the popcorn..
Use regular oil, but change on time. And use motorcraft filters. All you need. Engine will outlive the rest.
Did i screw up Errk20 2017+ Super Duty 4 07-24-2017 07:34 PM
synthetic change junorris 6.7L Power Stroke Diesel 30 06-11-2017 01:09 PM
1997 F150 4.6L ticking noise kabcpapc 1997 - 2003 F150 3 02-17-2017 06:18 PM
Loss of 1 MPG after 60k service tc0nn Oil & Lubrication 6 01-30-2017 12:27 PM
What engine oil do you use in your diesel? dwilli1969 1999 to 2016 Super Duty 16 09-21-2016 06:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
