Steering and Power Brake gone at idle. - Ford Truck Enthusiasts Forums
Old 12-07-2017, 04:38 AM
Hoss84 Hoss84 is offline
Hoss84 is starting off with a positive reputation.
I have an 06 F250 6.0L
The pulley on the tensioner locked up, tossed the belt. Drove it maybe 3/4 mile and parked. Replaced the tensioner and belt, now the steering gets hard only when coming to a stop along with losing power brakes. Above idle, running down the road both work fine. Ideas?
Old 12-07-2017, 05:37 AM
Yahiko's Avatar
Yahiko Yahiko is online now
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
Bad power steering pump or low on fluid.
Check level first. Brakes run on a hydroboost system. So if the PS is
having pressure issues the brakes will also. The system can also be tested
with the correct tool. A few other thing to check before throwing a pump at
it would be to see if there is an inline power steering filter element. It it's
plugged you will loose pressure. And were you able to spin the idlers by had
with the belt off? Also check the A/C pulley bearing to see that it spins free
when the clutch if disengaged. If any are stiff then start there first after
checking fluid level.
Might save on the cost of a pump.
Old 12-07-2017, 09:12 AM
TooManyToys.'s Avatar
TooManyToys. TooManyToys. is online now
TooManyToys. is a splendid one to beholdTooManyToys. is a splendid one to beholdTooManyToys. is a splendid one to beholdTooManyToys. is a splendid one to beholdTooManyToys. is a splendid one to beholdTooManyToys. is a splendid one to beholdTooManyToys. is a splendid one to behold
Or the belt is slipping if the tensioner is not correct.
Old 12-07-2017, 01:10 PM
Iíll dig into it, look for an inline element, do a system flush, etc. Fluid level, tensioner, belt and pulleys are all good.
2000 F250 Belt Problems Delkancott 1999 - 2003 7.3L Power Stroke Diesel 7 10-01-2017 09:11 PM
2003 6.0, no cruise and now no high idle 03X Excursion - King of SUVs 0 12-20-2016 12:29 PM
97 4.6 Pulley / Engine Noise cixelsyd 1997 - 2003 F150 2 10-20-2016 11:31 PM
Serpentine Belt Problem? CoreLokt 1987 - 1996 F150 & Larger F-Series Trucks 14 03-14-2016 07:13 PM
squeak Selfhl1 1987 - 1996 F150 & Larger F-Series Trucks 8 02-23-2016 12:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
