Need new glow plugs 85 Ford F-250 6.9 IDI DIESEL - Ford Truck Enthusiasts Forums
Old 12-07-2017, 01:47 AM
G.Christopher.L G.Christopher.L is offline
G.Christopher.L is starting off with a positive reputation.
does anyone have any suggestions on glow plugs? I want to make sure Iím not getting some low end ones that could screw me over in the end.
Also, does anyone have a good manual they use for this engine?
thanks!
Old 12-07-2017, 05:54 AM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Make sure you only buy Motorcraft or International brand plugs. They will have the name Beru printed on the plug. They are the proper original plugs and will not swell on the tips and break off in the cylinders.
Old 12-07-2017, 08:57 AM
Olds64's Avatar
Olds64 Olds64 is offline
Olds64 is starting off with a positive reputation.
X2
I bought Motorcrafts from RockAuto to replace the bad glowplugs in my IDI. I was very careful about removing the old ones because I read horror stories about the tips breaking off. I soaked the old glowplugs with PB Blaster for a week working them back and forth little by little. When I got them all out withou incident I noticed the Beru name on them.
Old 12-07-2017, 02:26 PM
grumpin's Avatar
grumpin grumpin is online now
grumpin is gaining momentum as a positive member of FTE.
X3 on the Motorcraft/Beru's.
I would use the Ford manuals, you can find them from Bishko on RockAuto or Dave Graham on eBay in CD's.
Old 12-08-2017, 03:17 AM
sdiesel sdiesel is offline
sdiesel is starting off with a positive reputation.
when you change plugs, change your relay switch too. 25 more dollars and all parts wear i and out together.
Old 12-08-2017, 08:36 AM
Olds64's Avatar
Quote:
Do you mean the glow plug controller on the back of the driver's head or the relay on the passenger's fender?
Old 12-08-2017, 09:45 AM
Franklin2's Avatar
Quote:
If it's working ok leave it. If it's one lesson I have learned in this day and age, new is not always better. There is a lot of junk being made lately.
Old 12-08-2017, 01:22 PM
Olds64's Avatar
That's sound advice.
I was just wondering because I am replacing the controller on my IDI since I am doing some major work to it.
I tested my glow plugs before I removed them per Festus' instructions on our site. They tested bad. Since I bought the truck the glow plugs have never worked right. I have some work to do.
Sorry, didn't mean to hijack the thread.
Old 12-08-2017, 01:31 PM
relay on fender is a relay.
controller is a controller.
the switch wears in proportion to the plugs, and one csn affect the other.
2011-2012 2 piece glow plug Jeffh40 6.7L Power Stroke Diesel 10 11-16-2017 05:44 PM
P1393 Saga Mike321 1999 - 2003 7.3L Power Stroke Diesel 13 04-30-2017 10:15 PM
Glow plug bypass with GPCM? andym 1999 - 2003 7.3L Power Stroke Diesel 3 04-10-2017 05:21 PM
Glow plug wire help Garrett Killgore Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 12-01-2016 06:07 PM
Snaped glow plug FarmallM4 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 14 04-17-2016 01:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
