Anyone having problem with the new trucks - Page 2 - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 12-07-2017, 10:19 AM
DSLTRK60's Avatar
DSLTRK60 DSLTRK60 is offline
DSLTRK60 is starting off with a positive reputation.
Quote:
Originally Posted by loggerkev View Post
No buy back program in Canada I have looked at legal actions with very little options I can take. Yea its a lemon alright we have a few other loggers around running these trucks with no issues. Believe the main computer is causing allot of it since when they looked into it half of the programming was missing. We are gonna Take it to PG Motors in Prince Gorge B.C Next. Will take it out tomorrow again and see how it does. It would be great if we had better lemon laws. my last f150 that was a lemon ford exchanged the truck for another since then I had 4 other new ford trucks no issues.
About CAMVAP - CAMVAP
IDK if you've heard about this, but worth visiting.
Old 12-07-2017, 10:47 AM
tony m 6.7's Avatar
tony m 6.7 tony m 6.7 is online now
tony m 6.7 is starting off with a positive reputation.
Mine has been great so far, 6k miles in 3 mos, the only issue I had was a rear sway bar clunk. I had the factory parts installed by my dealer and the tech put the frame to link brackets on backwards. Quick fix.
Old 12-07-2017, 10:48 AM
stewy604's Avatar
stewy604 stewy604 is offline
stewy604 is starting off with a positive reputation.
Did you buy the truck from PG Motors? If so, you'd think as the selling dealer they'd be willing to work with you a little better. Next bet I guess would be to try another dealer, closest to you would be Cariboo Ford in Quesnel. If it was me, I'd be trading out of it, even it means taking a hit.
Old 12-07-2017, 11:52 AM
johnso johnso is online now
johnso is starting off with a positive reputation.
8800 miles so far, not one issue, none
Old 12-07-2017, 12:43 PM
Tricon's Avatar
Tricon Tricon is offline
Tricon is gaining momentum as a positive member of FTE.Tricon is gaining momentum as a positive member of FTE.
8000 on mine, not a single problem. This has been the best truck I've ever bought on initial quality. Similar to my Tundra, which is amazing since Toyota is known for amazing reliability.
Old 12-07-2017, 01:10 PM
WyoBull's Avatar
WyoBull WyoBull is offline
WyoBull is gaining momentum as a positive member of FTE.
You damn sure got a lemon. Zero issues with my truck so far after 8000 miles.
Old 12-07-2017, 04:08 PM
loggerkev loggerkev is offline
loggerkev is starting off with a positive reputation.
Found out today there no programming in the computer for the adaptive steering. I'm guessing this is whats causing the most of the problems. When the engine had problems they discovered the same thing in the computer hopefully they will just put in a new computer and no more problems (might still only be a dream of no more problems)
Old 12-07-2017, 04:10 PM
Quote:
Truck was purchased from Cariboo Ford in Quesnel
gonna try PG motors next there mechanics seem allot more knowledgeable
Old 12-07-2017, 04:13 PM
I will try them again last time got a big run around them it was said that Ford them self was the issue and not the dealer and there was nothing they could do.
Old 12-07-2017, 06:24 PM
lotsofords lotsofords is offline
lotsofords is starting off with a positive reputation.
I am up to 21,000 miles. 6.7. So far I have had 2 huge problems. A RR inner tire pressure sensor and a LF tire valve core.
And for my driving, my fuel consumption has improved about 10%
Great truck
Old 12-07-2017, 06:46 PM
dustin cri dustin cri is offline
dustin cri is starting off with a positive reputation.
so far not bad but my rear doors keep staying locked when its cold out.... have to leave in garage for a couple days to dry out about. broken battert clamp
Old 12-07-2017, 07:12 PM
DRKBC DRKBC is offline
DRKBC is starting off with a positive reputation.
Quote:
I had the opposite of this, doors opened but the passenger door wouldn't shut after they opened. I played with the lock and was surprised to see the internals for the door locks are plastic rather than metal, they honestly don't look to super duty. Anyway ... the passenger door lock wouldn't engage, so I had to drive in with my passenger holding the door back from flying open for the trip to work, not too safe. I kept trying the automatic locks and about half way there it engaged and my passenger was able to safely let go of the door.
I sprayed all the locks with WD 40 in hopes that it would wick whatever moisture was in there - out. So far so good, it wasn't so much the door freezing up as much as how cheap the locking mechanism looked.
Speaking to the OP that is unfortunate. Traveling off road in BC and Alberta can be very hard on equipment and I am sure your industry also takes its toll on vehicles. Ford bills these trucks as up for the task so I hope the dealer gets it figured out for you and it was just a random thing. You wonder in your world if you wouldn't be better with a sparse amount of options, just less to go wrong.
Really though for me I have had very few problems with this truck other than the odd strange behavior of some of the electronic gizmos: auto wipers going crazy, engine brake sticking in a gear anyway they all subsided so I guess time will tell.
  #28
Old 12-07-2017, 08:20 PM
ncl ncl is offline
ncl is starting off with a positive reputation.
There is a recall for the doors not latching. Fyi
  #29
Old 12-07-2017, 10:13 PM
Quote:
Thank you! I didnít know that.
  #30
Old 12-08-2017, 01:09 AM
mikemorales mikemorales is offline
mikemorales is starting off with a positive reputation.
just had one issue with mine. some seem on the front passenger door let water in and that caused a short that killed the top cabin lights in the truck. Took right under 3 weeks for repairs but all is well again.
Steering problems... please help! dakeddie 1999 - 2003 7.3L Power Stroke Diesel 6 08-23-2017 03:26 PM
Steering with a mind of it own rollnhvy77 1999 to 2016 Super Duty 10 07-22-2017 01:11 PM
Adaptive Steering 39 Unlimited 2017+ Super Duty 11 06-30-2017 08:43 AM
One thing leads to another Thipdar 1967 - 1972 F-100 & Larger F-Series Trucks 7 05-21-2016 03:02 AM
Aussie Locker: First Impression natewoz Offroad & 4x4 7 12-30-2015 09:05 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
