75 F100 dies when I take my foot off the gas.
Old 12-07-2017, 03:17 PM
Rhett Nebeker's Avatar
Rhett Nebeker
Rhett Nebeker is offline
Angry 75 F100 dies when I take my foot off the gas.
hey Yall. I dont have a lot of knowledge about truck but i and trying to make my grandfathers old farm truck my new daily driver. It is a 75 F100 with a 351m and a motorcraft 2100 carb. I recently rebuilt the carb and it was running great for a wile. i let it sit for a few week and now i can get it to idle. I have adjusted the mixture screws and the idle screw on the carb forwards and back and every position i have tried the truck starts right up and then dies. I have also replaced the spark plugs and check the disturber and wire. I dont know what else to do at this point. Any ideas?
Old 12-07-2017, 03:30 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Welcome to FTE
Easiest to check for spark when this happens. Pull a plug wire and install a spare plug and ground it. May need a remote starter switch or an assistant to turn key while cranking engine. Or check coil wire from disturber, it should be able to jump up to at least a 1/2" with a fat bluish spark to ground.
Old 12-07-2017, 03:52 PM
EQCMCAT's Avatar
EQCMCAT
EQCMCAT is offline
Rhett Nebeker,
Sounds like it could possibly be your choke not being set or not set enough or it's not functioning at all. Did you mess with the choke after you re-built the 2100 carburetor? Although I'm not an expert setting the choke, I have read numerous threads on this forum setting them.
As important, welcome to the FTE forum, like several others have said and may do again, there's allot of experience on this forum with it's talented members.
Don
gunshowjr
05-18-2017 12:40 PM
jake_whitman
30
12-16-2016 08:35 AM
Fish_Scientist
26
12-14-2010 06:25 PM
dan66tampa
02-06-2005 03:39 PM
Daymeon
01-01-2005 01:19 PM
Quick Reply: 75 F100 dies when I take my foot off the gas.
