I guess automatic is better
Been launching my boat in low water conditions and seems like it's easier with my automatic truck than my standard bronco. Seems like the newer automatic transmissions don't pop and start rolling backwards when you're on a hill like you just ripped out the parking pawl. Maybe it's because of the hill assist.
The water gets low around here during the winter and it's a little dicey being backed down the ramp and then
putting the clutch in.....holding the brake..... starting the truck (all the while attempting to remain above the water line) letting out clutch and crawling up the ramp slow enough to maintain traction
I know what you are talking about on the old automatics. The secret to preventing that is a properly adjusted emergency brake. If you apply it good and tight before putting it in park, and remove from park before disengaging it, you will not feel like your ripping the parking pawl out.
This.
I have always done it this way. Never once damaged a transmission.
But I do like the new transmission too.
jmadsen
09-13-2010 09:35 AM
joecool177
1983 - 2012 Ranger & B-Series
11-07-2002 09:11 AM
larry derouin
07-24-2001 07:22 PM
