Again!?! Another broken tie rod end... stranded
for some reason.. I seem to become the collector of old point dwell meter and timing light devices... anyone that knew I fixed cars seem to think I might need them... after 6 each.. I hand them back
that's OK,,, I still have 2 working VTVM's ( Vacuum Tube Volt/Ohm Meters)... for the younger sets.
if its one off.. sure... its a part made by a man an a machine...
I have replaced tons.. on cars and trucks.. over 50 years... maybe a 1,000, no joke.
in the 1970's you were lucky to get a tie-rod end last 3 years or 40,000 miles....
just like Brakes, tires, wheel bearings, water pumps, almost every part needs replacement.. at some point.
OLD Guys.. remember tune-up every 12,000 miles with Points..... ! and I am 66 years old.... so I am not talking 1900.
back in the day.. you were lucky to get a NEW truck to last 100,000 miles.. Gas or diesel...
I told my children my 1st truck had the choke on the dash, it was cable driven.......they looked lol puzzled and said “ WHATS A CHOKE?”
LMAO......
Points to a 32 Ford, would fit anything.......
you can ask his for a point file.......that will really blow his hat in the water.....
point files... steel or fiberglass.. I still have both
chokes with hand operated cables...... classic.... before heat and/or vacuum controlled..
like mechanical linkage for (3 ) 2bbl carbs.....
or (2) 4bbls.... aka duel quads.
what about the "Vortex Magneto "... or Duel Point distributor... without vacuum advance...
I go back to the 348 and 409 days... I was a pro-wrencher.. and weekend drag racer since 1967
also played with a few 352 and 390's and ONE 332.. a 1959
I know.. I have derailed another thread... like a 4884.. for all you steam locomotive fans .
with truck on the ground
then tape measure from tire to tire.. first front side then rear side of front tires...
gets real close.
Dont worry, Ive done this before... imho, couting the turns doesnt work unless you are putting motorcrap back on
Harrier
121
03-27-2017 04:14 PM
Schuyles
04-30-2013 10:12 AM
