VIN plate picture - Ford Truck Enthusiasts Forums
VIN plate picture
Old 12-04-2017, 07:11 PM
catimann
catimann is offline
catimann is gaining momentum as a positive member of FTE.catimann is gaining momentum as a positive member of FTE.
VIN plate picture
does anyone have a picture of an old VIN plate or some such thing and where it would have been?
Old 12-04-2017, 09:21 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is online now
GB SISSON has a spectacular reputation.GB SISSON has a spectacular reputation.GB SISSON has a spectacular reputation.GB SISSON has a spectacular reputation.GB SISSON has a spectacular reputation.GB SISSON has a spectacular reputation.GB SISSON has a spectacular reputation.GB SISSON has a spectacular reputation.GB SISSON has a spectacular reputation.GB SISSON has a spectacular reputation.GB SISSON has a spectacular reputation.
Not a plate. That is other info. The VIN# , the one we all need for a title is stamped on the top of the frame, usually in front of the steering box. Maybe anywhere around the left (drivers) side frame horn.
Old 12-05-2017, 12:37 AM
catimann
catimann is offline
Ok thanks. Then where was this other plate and what did it look like?
Old 12-05-2017, 01:36 AM
Rickster800
Rickster800 is offline
Rickster800 is gaining momentum as a positive member of FTE.Rickster800 is gaining momentum as a positive member of FTE.
Hi
This VIN Plate is inside the glove box door. It is attached with the same 2 screws that secure the handle to the door. Many times these are missing. These plates were on trucks from 1/2 ton and heavier. A 1 ton would have a capacity of about 8500 lbs. This one is from a larger truck. They were secured this way on trucks in '46 & '47. Later models after '51 had the plates secured to the firewall. Almost all trucks from '43-'45 were made for the military and secured to the dash panel.
Old 12-05-2017, 04:30 AM
46fordtruck's Avatar
46fordtruck
46fordtruck is online now
46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.
Originally Posted by Rickster800 View Post
This VIN Plate is inside the glove box door. It is attached with the same 2 screws that secure the handle to the door. Many times these are missing. These plates were on trucks rated 1 ton and heavier. A 1 ton would have a capacity of about 8500 lbs. This one is from a truck rated for more than 1 ton. They were secured this way on trucks in '46 & '47. From '48 on up, the plates were secured to the firewall. Almost all trucks from '43-'45 were made for the military and secured to the dash panel.
Actually, not correct. The rating plate was used on all trucks, not just 1 ton and up. The 1/2 ton showed a rating of 4700 lbs.
1948-51 also had the plate on the glove box door as well, it was not attached to firewall
Old 12-05-2017, 06:00 AM
Rickster800
Thanks for the additional info on the locations of the plate. I updated my post.
Old 12-05-2017, 05:53 PM
oldrelics
oldrelics is offline
oldrelics is starting off with a positive reputation.
Don't forget these are Canadian
Old 12-05-2017, 07:33 PM
bernette's Avatar
bernette
bernette is offline
bernette is a name known to allbernette is a name known to allbernette is a name known to allbernette is a name known to allbernette is a name known to allbernette is a name known to all
that firewall is nice!
Old 12-06-2017, 10:55 AM
catimann
catimann is offline
For some reason I highly doubt that any kind of plate like the one above is available now.
I know those were made as a raised letter/numeral embossment and that was done with a machine. The hardest part would be finding the right kind/size of letters to do the job.
This is the closest contraption I have found.
Old 12-06-2017, 11:16 AM
catimann
catimann is offline
This is interesting, just may work.
76f350spercamprspeal
97
04-03-2016 10:16 PM
jomoflymo
07-14-2014 04:04 PM
black58
04-06-2009 02:58 PM
david11690
05-10-2005 11:54 AM
Beachbumcook
05-31-2004 05:47 AM
Quick Reply: VIN plate picture
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
