2015/2016 6R140 auto transmission interchange
Seems like the bolt pattern to block is different. Maybe someone will chime in to verify that.
FC3Z-7000-SRM 6.7L Remanufactured Automatic Transmission Assembly 4WD
CC3Z-7000-V 6.7L Transmission 2WD
FC3Z-7000-F 6.2L Transmission 4WD
FC3Z-7000-C 6.2L Transmission 2WD
I don't know for certain, but when I was at Ford (until 2007) they had standardized the bolt patterns. I do know for certain that the 6.0L/6.4L had the same bolt pattern as the 5.4L/6.8L gas engines. I wouldn't expect that they changed that with the 62.L and 6.7L. Creating a new bolt pattern costs millions in tooling. It's WAY cheaper to have one bolt pattern.
I would expect that the internals are different, such as different clutch plate counts in some of the clutches due to the very different torque inputs.
darkpurp1e
02-07-2012 01:22 PM
Rusty_Old_F250
04-15-2011 02:22 PM
muscletruck7379
03-04-2007 07:47 AM
