Newbie IDI 7.3 questions - wiring and fuel
Old 12-04-2017, 02:50 PM
hyghlndr's Avatar
hyghlndr
hyghlndr is offline
Looking for help with two issues with an IDI 7.3 swap.
Anyone have a basic wiring diagram with just the minimum wiring to run? I have most of the factory engine harness but need to figure out connections.
On the fuel filter holder housing there is a small black tube that almost looks like a vacuum line? Where does it go? Function? (it is not the fuel line or wiring)
thanks
Old 12-04-2017, 06:24 PM
Peter A.'s Avatar
Peter A.
Peter A. is offline
You really should invest in a manual if you are going to be playing under the hood. The line that you are describing is a fuel return.
Old 12-04-2017, 10:18 PM
Macrobb's Avatar
Macrobb
Macrobb is offline
Yeah this Hayes/Chilton Diesel manual is decent, and widely available: https://www.xtremediesel.com/haynesd...cabegkjnfd_bwe
Usually you can find it at your local auto parts store.
As far as 'wires needed to run'...
1 wire from the "fuel shut off solenoid" on the IP to power.
That's all.
To start it, though, you either need to use ether, or rig up the glow plug controller setup.
Also, you'll end up wanting to run power, through the temp switch on the block(passenger side of the IP, near the front) and to the "high idle" solenoid, and cold idle advance.
Old 12-04-2017, 10:24 PM
hyghlndr's Avatar
hyghlndr
hyghlndr is offline
Thanks everyone, I purchased an IDI swap into a Bronco and working on getting running.
classic19_98
09-20-2014 09:29 PM
obsguy
02-09-2014 11:07 PM
bluesmanmike5
10-22-2010 01:13 PM
chevma-67
06-07-2006 11:45 AM
Woodlums
10-04-2005 08:57 PM
Quick Reply: Newbie IDI 7.3 questions - wiring and fuel
