2005 5.4 V8 manual tranny? - Ford Truck Enthusiasts Forums
Old 12-04-2017, 11:07 AM
6.8LV10's Avatar
6.8LV10 6.8LV10 is offline
6.8LV10 is starting off with a positive reputation.
I have a 2005 150 XLT with the 5.4 Triton. Which manual tranny did it have? the ZF-5?
Old 12-07-2017, 04:02 PM
ZSK ZSK is offline
ZSK has a good reputation on FTE.ZSK has a good reputation on FTE.
A 5.4 or 4.6 V8 in the 04-08 F150 was not offered with a manual transmission.
There was a manual transmission option for the 4.2 V6 in 2wd, M5R2. *4.2 V6 was not available in the 2004 F150.
In the F250 and F350 models, a 5.4 was available with a ZF6 or ZF5 depending on the year.
Old 12-08-2017, 02:20 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman has a good reputation on FTE.1saxman has a good reputation on FTE.1saxman has a good reputation on FTE.
The 4.6L V8 was available with the 5-speed manual in 2007 and probably some other years too. That is a swap I wouldn't mind making some day.
Old 12-08-2017, 02:22 PM
6.8LV10's Avatar
Damnit. Not gonna try to fabricate something. Welp.
Old 12-09-2017, 10:07 AM
P.Bronner P.Bronner is offline
P.Bronner is gaining momentum as a positive member of FTE.
If the 4.6 V8 had a manual option, the hardware is probably the same. The obvious remaining issue would be the electronics. The PCM would be expecting several feedbacks that it would not be receiving, but this may not create anything more than a flashing O/D off light. Thats the transmissions version of "check engine". I don't think it would create any problems on the engine side of the equation. The transmission strategies are dictated largely by inputs from the engine. RPM, load condition etc,. The PCM uses this info to tell the trans. what to do, but I don't think the trans has any effect on the engine. Basically the engine doesn't know or care what the trans. is doing. I think it's doable, but you may have a couple gremlins to live with afterward.
Old 12-10-2017, 06:13 PM
Maybe I spoke too soon. I just read on another site that the 4.2 has its own bell pattern.
Old 12-11-2017, 10:53 AM
ZSK ZSK is offline
I've spent some time researching the subject and always come back to using a zf5 or zf6 from the 5.4 and 6.8 engines found in the super duty trucks. The Mazda trans really isn't well suited for "truck" use and wouldn't last well behind a 5.4
All of the ford literature I've seen shows the 4.6 with a manual transmissions ended with the 2003 model year. Here's the tow ratings published in 2007/2008 showing only the 4.2 V6 with a manual trans.
Old 12-11-2017, 07:25 PM
Wow, it really knocks the **** out of the towing.
2005 F350 5.4 catalytic converter bolts Lorrainethef250 1999 to 2016 Super Duty 3 10-11-2017 05:24 PM
5.4 starter removel on a 2005 f150 4x4 med0989 2004 - 2008 F150 2 02-23-2017 10:39 PM
Electrical schematics needed for 2005 pcm to power dist box e350 5.4 fleet model Vasvic 1968-2013 Full Size Vans 0 10-16-2016 04:16 PM
2005 SD Pricing Corey Moeller 1999 to 2016 Super Duty 1 09-30-2016 08:27 AM
2005 f150 engine swap Joesauto 2004 - 2008 F150 7 01-28-2016 08:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
