Strange Whistle in my Engine Bay - Ford Truck Enthusiasts Forums
Old 12-03-2017, 10:01 PM
Murf-150's Avatar
Murf-150 Murf-150 is offline
Murf-150 is starting off with a positive reputation.
I have a 2002 F-150 V-8 and I'm getting a strange whislte in the engine bay.
I've tried to track it down but it eludes me.
As I'm driving, when I step on the gas it quiet dows slightly and when I let up on the gas that's when it gets louder. By louder I mean just a constant whistle.
It seems to be more noticeable when the weather is cold.
In the summer it would go away after a few miles. No that it's cold, it seems to last longer.
Anyone ever have this noise?
Old 12-04-2017, 01:24 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
While it is whistling, disconnect the IAC and see if the whistle stops.
Old 12-05-2017, 11:36 AM
Murf-150's Avatar
Pdqford,
What is the IAC?
I did notice after a drive of about 10-15 miles the noise went away.
I performed a code reader check and no codes were present.
Like I said before, it seems to only happen when it’s cold outside.
After the engine warms up it seems to go away.
I’m stumped.
Old 12-05-2017, 11:40 AM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
Sounds like exhaust gaskets leaking. See if its louder in one of the wheel wells.
Old 12-05-2017, 11:44 AM
Murf-150's Avatar
It’s like a smoke alarm in your house. Hard to find where the noise is coming from.
When I open the hood it’s loud but not screaming loud.
Any chance it could be the serpentine belt?
Seems to be more to the front of the engine.
Old 12-05-2017, 05:15 PM
Quote:
Originally Posted by Murf-150 View Post
Pdqford,
What is the IAC?.
Sorry. IAC is the Idle Air Control.
Old 12-05-2017, 05:51 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is online now
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
to check the belt, take a spray bottle and squirt a little water on the belt while running and see if the squeak changes or is eliminated........ for alternator and idler bearings, you take a short pipe or LONG screwdriver and touch the housing by the bearing, then rest the other end against your ear and listen for grinding... compare 2-3 bearings until you get the "bad" noise figured out.
Old 12-06-2017, 12:01 AM
Murf-150's Avatar
Strange whistle in my engine bay.
Thanks to all of you who took time to help me out.
Iíll keep you posted with the result as soon as I figure it out.
Again,thanks!
Murf-150
Old 12-06-2017, 12:18 PM
You could also take the belt off and start it. No noise=belt driven component causing it
Old 12-06-2017, 10:33 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a very good reputation on FTE.Bluegrass 7 has a very good reputation on FTE.Bluegrass 7 has a very good reputation on FTE.
The whistle is likely a vacuum leak.
Under idle and low speed throttle openings, the vacuum is the highest at near 20 inches.
As you open the throttle the vacuum goes down and changes the sound you hear.
Get a Stethoscope at the auto store, remove the probe and hunt for the leak with the handle opening same as a Doctor uses his.
Or use a small piece of hose to your ear.
Be a Marine, improvise.
Good luck.
Old 12-07-2017, 02:58 PM
Again,thanks!
Murf-150
So, did you try unplugging the IAC when it is making the noise.
That should take all of 15 seconds to check.
That was the issue on my 2002 Navigator when ever the temp dropped below about 25 degrees F. Sounded like a smoke alarm going off. If you goosed the throttle It might stop or if the temp was above 25-30 degrees no more noise.
As soon as I unplugged the IAC the noise stopped instantly. I think my IAC was
marginal and slightly sluggish at the lower temp and it would rapidly cycle back and forth between more air and less air, but couldnít react fast enough, thus the cycling and that embarrassing noise.l
Strange whistle in my engine... Murf-150 1997 - 2003 F150 6 12-08-2017 08:50 PM
88 F150 Down shifting when Letting off the gas Jeff Metz Jr. 1987 - 1996 F150 & Larger F-Series Trucks 1 06-08-2017 03:32 AM
1994 F250 7.3 idi turbo whistle Nick9219 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 03-24-2017 11:34 AM
Whistling or Leaking Noise 2005 F150 Addison3000 2004 - 2008 F150 4 10-19-2016 06:20 PM
Turbo whistle upgrade Willk98k 1994.5 - 1997 7.3L Power Stroke Diesel 9 12-18-2015 09:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
