Electrical Manual - Schematics, troubleshooting
HI,
Whats the best manual for schematics and electrical test procedures.. I guess the Ford Service manuals are pretty good obviously, keep in mind I wont be using Ford test equipment so... I bought this CD on Ebay and although informative the electrical diagrams are not working on my PC.
Chilton or Haynes ?? I know Ive had some Haynes in the past that worked rather well on GMC's etc...
I have lots of electrical issues to troubleshoot.
THanks
THanks
I finally got this CD to run that I bought on Ebay. It's genuine Ford item and it is impressive. You click on the connector and it shows the pinouts, then click on location and it shows you it's physical location in the vehicle.. it was 12.99, just a bit of a pian to run on a newer PC, have to install the correct version of Abobe SVG viewer.
TElls you what pins to pinout and the desired result, all the colors are clearly notated. I am saying it's recommended right now.
Much more economical that the paper version.
thanks
thanks
StickFig
04-07-2016 10:36 PM
sauerf100s
04-12-2002 07:14 PM
