Eaton Fuller 9 speed road ranger question.
I’ve been gathering info of all the major components of this L8000 I bought. With regards to the transmission, the sticker on the sun visor says it’s a 9 speed. When shifting it out on the road, there are 8 standard forward gears, plus the low gear. So, I know it’s a 9 speed. But when I crawled underneath and found the tag, it shows the model as “RT6610” which is a 10 speed. Because of this, I don’t know what model 9 speed it is. Any thoughts? Thanks. John. I’ve included pictures.
The transmission does not match the tag. That is a low torque 10 speed like would be used behind a 3116/3126 Cat, or a 6.6 Ford engine.
It's rated for 600 ft lbs torque. It shifts 5 on the low side, flip button up, repeat same shift pattern for gears 6-10.
The 6610 is a direct drive transmission also. What engine is in your truck?
If you're able to shift from low to 1st without the truck almost stopping before going into gear, then you most likely have a 10 speed.
There is such a big ratio difference between low and first in a 9 spd, shifting quickly is all but impossible, while with a 10 spd, 1 to 2 will change just like any other gear.
I just went through all of the gears. It is a10 speed. The tag is correct. I guess at some point, the transmission was changed out. Or, they had to replace the sun visor and could only find one from a 9 speed truck. Lol. Any way, it doesn’t matter I just needed to know what I had. Thanks guys. So, is the RT6610 a decent transmission? This truck will be used to pull a backhoe, which combined with the trailer weighs about 20K.
moose94
05-10-2005 11:06 AM
Ron_CNY
09-24-2004 11:53 PM
Mike W
11-20-2002 07:25 PM
