Well its mid 60 in Sacramento today, was cold last night...but sun has warmed it up nicely. I'm sitting out having my second cup of coffee and a cigar trying to decompress and unwind. Not sure what I'm going to do today but I feel like being "gone fishing". Would need my fishing pole and such first though.
Not sure if the diesel or my joints complain worse on mornings like this.
I hear ya Will , been laying across the Engine for the last 4 hours , noticed a drop in coolant , come to find out the hose that wraps around the Ficm to the heater core had a leak , started on that , moved the Degus for more room Snap goes the Y, Ohhh $#*+, also more coolant on the Ficm , Yep Degus was leaking Too, , got the core hose on and called it a night
Back at ya. Had breakfast Friday morning with some friends. When I left our house (at 2400' elevation) it was 65 degrees (short sleeve weather). When I got down to Cupertino, it was 36 degrees. Hooo! Need a jacket!
Yes indeed. Went to the local Walmart grocery market, which is only a half mile west of here. And it was brisk but not bad on the way there. but coming back, oh boy, was it cold. I did not bring the normal thick jacket I usually ware, and I was freezing by the time I got back.
Where was your degus bottle leaking from? I've noticed mine has a little cracking going on but no signs of leak there, though my coolant level did drop slightly so...
I had three leaks , the Degus on the bottom right over the Ficm , when under pressure it would spray on the top of the Ficm , the hose that wraps around the Ficm and connects to the heater core , right where the lower right hand Ficm **** or under screw mount rubbed a hole in the hose, at the other end of the same hose after the metal to rubber crimp it was wet and starting to leak,The Degus Y when trying to lay the bottle out of my way snapped , so had to replace that Y hose to the water pump, I found something else FYI from the Dealer , If your a Contractor or Ag make sure to Tell them , I received a nice discount on all the Parts, although I had to go to two different dealers to get them , I still got the discount. You’ll see a big puddle or notice the Ficm wet if the Degus is leaking , also check the heat control arm on the passenger side engine bay where the small grey hose plugs into.
