6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
09 6.4L straight pipe
Old 11-30-2017, 07:36 PM
Leonardmcclure's Avatar
Leonardmcclure
Leonardmcclure is offline
Leonardmcclure is starting off with a positive reputation.
did the DPF,EGR delete straight pipe no cat. it sounds like a big hair dryer as you give it foot feed. and Rick Flare ( WOOO ) as you let off. is this normal for that motor?
Old 11-30-2017, 10:07 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.
Sounds similar to what my truck sounds like. The hair dryer part at least.
Old 12-01-2017, 01:21 PM
Picton's Avatar
Picton
Picton is offline
Picton is starting off with a positive reputation.
Agreed. If you delete those exhaust/emissions components...that is exactly how it will sound. Like a hair dryer from hell/jet engine (turbo whistle). I've gotten used to it personally. But if you wanted a more deep tone...5" exhaust from the turbo back would give you that. There are some good examples on Youtube of 6.4 exhaust notes with differing pipe sizes. I just put in 4" delete pipes and left the rest stock (3.5") so I get the higher pitched angry scream/whistle if you get on it a little. Doesn't take much.
Old 12-02-2017, 06:26 PM
Leonardmcclure
Did you use a waste gate? I'm still on the fence if I need one or not.
Old 12-02-2017, 08:45 PM
Firefighter 1406
From everything I have read you don't need to worry about a wastewater unless you are running a hot tune = over 40 psi boost. That's at least the info I have seen. I have look into them but haven't seen anything that would point to the fact that I need one yet with the current mods on the truck.
Old 12-02-2017, 10:16 PM
Picton's Avatar
Picton
Picton is offline
^^^What Seth said. "Wastewater" though...Lol. I've read the same. For those of us that can keep our foot out of it 99% of the time...we should be okay without one.
Old 12-03-2017, 08:54 AM
Firefighter 1406
Auto correct has been kicking by butt lately!!!
Old 12-03-2017, 10:06 AM
Copper.Farm's Avatar
Copper.Farm
Copper.Farm is offline
Copper.Farm is gaining momentum as a positive member of FTE.Copper.Farm is gaining momentum as a positive member of FTE.
Hair drier or vacuum cleaner sound is normal as the exhaust goes through the turbos.
Old 12-08-2017, 07:38 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is online now
speakerfritz has a good reputation on FTE.speakerfritz has a good reputation on FTE.
interesting...
Old 12-20-2017, 11:12 AM
StrangeBrew69's Avatar
StrangeBrew69
StrangeBrew69 is offline
StrangeBrew69 is starting off with a positive reputation.
Why would you need a waste gate running a hot tune? It will not damage your diesel like it would a turbo charged car engine. I am running a 4" downpipe to 5" straights that Y in the back to 6" tips. It doesn't sound like a hair dryer more like a jet engine. Just a little quieter than the guys running the single pipe.
Old 12-20-2017, 01:32 PM
Robert Green
Robert Green is offline
Robert Green is starting off with a positive reputation.
people who delete the EGR are the ones who are supposed to need the wastegate
I have run HD300 tunes with the EGR disabled, but still haven't left the 20psi range, even when passing people on the highway
I would get into the 30's when I was running my DPFR
Old 12-20-2017, 02:00 PM
StrangeBrew69
i have my egr deleted. i hit 40 psi of boost on a 250 hot tune and i dont use a wastegate. just have turbo farts. which will not hurt it any. also good to clean the turbo more often when your running hot tunes. some good cleaning videos on youtube.
Mikedaneyoung
01-31-2018 08:39 PM
Ford526
2009 - 2014 F150
04-10-2013 07:53 PM
A/Ox4
17
07-12-2012 07:15 PM
rchouser
01-04-2008 04:49 AM
cvdenson
11-11-2007 11:06 AM
Quick Reply: 09 6.4L straight pipe
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
