Well another question. I take 10,000 pics and didn't take one of the gas pedal. I can see how the linkage goes into the cab, then I assume the pedal is bolted down, but... Is the small **** on the top of the gas pedal just slip into that spring loaded piece at the end of the linkage? are there any other springs required or pieces to that besides the boot? I cant find a pic anywhere online with details. Any help or pics would be great!!
WOW - thank you for the pictures, Ross. I was absolutely damn sure some shade tree mechanic attempted to repair a broken linkage at my Truck simply with a spring wrapped around it. Was really about to weld that together again - and already wondered if it would align properly after doing so....
So it looks like all I have to do is take that small weldied end off. And get the spring and ball set up, and get a different gas pedal. I’d rather Do it right the first time. Thanks for the info.
It looks as though The previous owner just added that small link Peace to where the old spring would have been. I am thinking a spring, a ball, and a gas pedal will match right up.
Thanks for that.
My stump's pretty worn after all these years. I'm guessing that
spring slides over it on one end and the ball piece slides into it
on the other side and attaches to the gas pedal.
