Electrical issues? - Ford Truck Enthusiasts Forums
Electrical issues?
Old 11-29-2017, 04:53 PM
Ernie111 Ernie111 is offline
Ernie111 is starting off with a positive reputation.
Electrical issues?
1972 f100 360, starts and runs fine for eight minutes only! Sounds like something failing after heating up. Any ideas?
Old 11-29-2017, 04:57 PM
Brian1971f100's Avatar
Brian1971f100 Brian1971f100 is offline
Brian1971f100 has a very good reputation on FTE.Brian1971f100 has a very good reputation on FTE.Brian1971f100 has a very good reputation on FTE.
Points and condenser? Go get them from ford, as the quality is much better then the China garbage.
Old 11-30-2017, 06:57 AM
GaryKip's Avatar
GaryKip GaryKip is offline
GaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to behold
2X Brian1971f100's comments. Condensers that are going bad overheat and shut down.
Old 11-30-2017, 08:22 AM
1968 F250camper 1968 F250camper is offline
1968 F250camper is starting off with a positive reputation.
I had condenser issues a few years back. Engine ran like crud and I couldn't figure out what the issue was. I finally installed an electronic ignition, and have not had an issue since. Also, coils will fail when they get hot. You might start with those two things.
Old 11-30-2017, 08:51 AM
orich's Avatar
orich orich is offline
orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.
When was the last time you did or had it tuned up> There old classics need attention about every 12-15000 miles as the points needed resetting or re-placing.
The condensers don't normally fail but one never knows when they will even if made in Mexico at best or us made.
spark Plugs & the wires, dizzy cap, points & condenser should be bought at a Ford Dealer
an not any Chinese or any off shore places.
If you think you'll save money an just go to a auto parts store to buy all you needed parts. Then we here can't help you after that cause of the point & condensers have a high failure rate.
The dizzy vacuum advance should be checked or replaced also when doing a tune-up.
An most shops would do a compression check first!
Orich
Old 12-07-2017, 12:16 PM
Thanks for the tips! I also hear that the resistor wire from ignition switch to coil may be failing. At least I now have a direction to go in. I will report back!
Old 12-07-2017, 12:29 PM
MIKES 68 F100's Avatar
MIKES 68 F100 MIKES 68 F100 is online now
MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.
had same issue when i first got my 68 . for me it was a bad coil only failed after engine got to temperature .
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
