Tires and Rain-X, respectively
I was really disappointed with Rain-X the first time I used it, it worked okay the first couple of rains but it lost its water shedding ability very fast. I tried it again years later, saturated a clean cloth and kept turning and wiping over and over until the cloth was dry, then re-applied it again the same way about a month later, and it lasted for a decade.
But give it a few days to dry before the rain hits, and it's a very different ballgame.
Then use the Rain-X windsheild washer fluid as your regular washer fluid, and you will be good to go.
I try to re-apply about once a year.
tires depend on the load you're hauling. if you are at or near max load on a regular basis you should be at recommended tire pressures. rears at 80psi, on the fronts 60 is recommended but I like them at 65psi and haven't had any issue with wear or driving in any weather conditions.
I don't know anything about Rain-Ex but I keep a bottle of Windex in the truck a couple rolls of paper towels and new wipers every 8 months or so. remember to clean the wiper blades when you clean the windshield. road oils and crap build up on them very easy and ruin their cleaning ability.
Baggins
Aerostar
03-15-2007 03:51 AM
