Complete "How To" Halogen to LED Heads & Tails
Originally Posted by troverman
Great instructions, jmeo. This should be a sticky.
One other question: you mention removing the "outage" wires. I'm assuming the halogen lights have the ability to tell the computer when the bulb fails, but the LED's do not?
I suppose someone starting from scratch could run all four from the BCM and not make the line change with ForScan if they wanted to.
Thank you! On LED vehicles there are 4 additional wires that come from the BCM. Left and right DRL wires and left and right outage wires. When I first started this project I was unaware of the outage wires so I only ran the two DRL wires. I was able to make them work correctly without them simply because of ForScan changes so I didn’t go back and add them.
My first 2017 F-350 had the factory LED lights; my current 2017 does not. I'm contemplating doing the changeover. However, I have a snow plow installed on this truck. I wonder if plow lighting would be affected or cause any problems in the conversion. For example, when you plug in the plow connector, your headlights automatically shut off and switch to plow lights. Not sure of what wiring was done to make this happen.
First off thank you for this! The LED lights is the one thing that was a must have originally for me but timing of selling my other vehicle and having to find the replacement pushed me to have to get a truck that did not have them but had a bunch of other options I really wanted. I figured adding LED's wouldn't be to bad of a upgrade so I moved forward with the purchase. I still want to add BLIS and possibly adaptive cruise one day but LED's are high on my list to be done before them.
Unfortunately cannot see the images while at work but are the pins for the left and right outage wires notated for someone that would want to run them to be 100% stock configuration?
I'm guessing the likelihood of a bulb out on an LED setup is considerably less than on the halogen / incandescent setup. Nevertheless, I think having the bulb out warnings is a great feature, and something Ford did not offer at all on previous generations.
I added the parts list to auto nation ford white bear lake and got 3611.81 plus 188.59 shipping. not knocking it, i really want them on my rig and i'm sure they can be found cheaper, i just wanted a ballpark figure for myself.
EDIT: Tasca Parts was same price but cheaper shipping
Right, in hindsight I would have run the outage wires, but not because I will ever worry about them being out, but because I was there anyway running the DRL wires. If I were any of you starting from scratch I would just run them with the DRL as it wouldn't be a big deal to run 4 instead of 2 wires.
#28
