Using Explorer rear AND leafs on a 53-56
I've search extensively and only found one example (ben73058). Has anyone else successfully used the Explorer leaf springs along with the 8.8 rear.
My truck will have a MII with 2" drop in front. I want a leaf spring rear. I don't mind some rake, but nothing extreme. It will be a driver and occasionally used as a truck.
I know TCI has a spring kit, but $500 is a bit steep. I'm fine with fabricating so "bolt-in" is not necessary. I was hoping to find some 8.8 leaf spring examples to look at. Or what other leaf springs were used successfully?
Thanks.
Phil
Thanks.
Phil
Hey Phil,
Our truck is up in Waco with my son. I'll take some pics of the
rear set up so you can see what we did. We did not use the
odd 3rd shock absorber mounted on top of the 8.8 diff. I couldn't figure
out what to do with that though I will say I'm tempted to put in a rear stabilizer bar to see what impact that might have.
I was initially concerned replacing a big pack of F1 springs (8?) with just
the 3 Explorer springs but it works fine. We carry all kinds of loads with no issues.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Received 4,130 Likes
on
The following users liked this post:
I have an explorer rear and spring with ranger shackles in my 56, I did not remount the perches on the rear end causing the need to narrow the the ranger shackles and left me with 9 degree pinion angle that was corrected with 5 1/2 degree shim, this leaves me with 2" clearance between the axle tube and the frame (not much travel) and less then 1" between the brake line tee that sits on top of the center section and the bed floor, I also run a 1" wheel spacer.
