FORSCAN for hire?
#31
and btw...while the donation of blood is giving from the heart (for free) - BLOOD isn't free - hospitals charge (significantly) charge for it.
#33
That does bring up an possible dilemma - what if you volunteer to help someone and you screw up their truck? Or what if the person you've gone to help didn't bother to procure a USB drive to load the original settings onto and you didn't bring one? Do you proceed with making changes anyway?
I suppose ethical questions like that are getting in the way from me raising my hands and volunteering to do the Forscan stuff for a future friend. However if my son asked me I'd have no problem doing it. He can forgive his old dad.
#34
I have two memebers here reach out to me and am very greatful, looks,like I might be getting this done this weekend.
This is an awesome place and am very greatful for nice people who just want to help someone out.
Good people out there. I hope to return the favor some day to a fellow member here as well.
Respectfully,
Shane
Respectfully,
Shane
The following users liked this post:
#35
on
I'm sure there are ways to screw it up, but if you're careful it should go well. I had no problems.
Also, I've always asked the truck owner to actually make the change. I provide the laptop, the OBDII connector and tutoring. This saves a couple of steps not having to install FORScan on their equipment and trouble shoot problems there. If in some weird circumstance someone would have a problem and blame me for it, I can always default to the fact that I didn't actually make the change, they did. Just keep your fingers off the keyboard and it would be hard to make a case that you caused the problem. You can also make sure you have them read the disclaimer on the spreadsheet that absolves you of responsibility.
Sad that we have to consider these things but I'm afraid he have to nowadays. You can't always know when you're dealing with a Weirdy right away. You just need to make reasonable accommodations to CYA and go about enjoying life. Some of the greatest enjoyment comes from helping others.
#39
I will add, if you get an update to your module(s) like I did during my last dealer visit... as I wanted him to initiate the DPF% screen, all my custom set line codes were reset back to OEM defaults. Also, my DEF screen that I setup in the top right (like instead of Turbo PSI) was back to default. I had to reset all my custom settings.
So just a thought, if you FORScan, don't think that you won't have to re-do it later on if you get re-flashed at you dealer.
#40
I will re-FORScan as I will not be liking the double horn honking. Makes very unhappy neighbors at early morning campsite evac's.
Anybody in my area, I will help out with this but I may do like Epic, tell you what to click and key-in, as this more or less takes liability over to them. Oh, no charge either, just happy to help our community.
#41
#42
I will just go in and find the line and make the change within that module. I actually wrote all the numbers/letters down pre and post. It's actually very easy Hex code, just go slow and re-read/write down all your OEM lines and post/altered lines. I keep this note in my glovebox.
#43
I plan on making some adjustments as well. I am planning on getting the equipment to do it myself. However, I would feel much more comfortable having the assistance of someone with prior knowledge of the subject. Anyone in South Carolina? I'm in the Upstate but travel around SC and western NC a good bit. Then, once I know what I am doing, I will offer my help to others. On the other hand, if anyone has no clue like me and wants to mess their trucks up together, let me know. I'd be way more confident with someone their egging me on.
#44
(i.e) High Beams on with Fogs LED users (Bambi mode). Halogen is different!, but all noted on the FORScan spreadsheet.
In the BdySM module; 726-27-01 you find this feature (again for LED owners). You simply change (only) one character place (out of the 12 characters listed), from "1" (Default=no in this case) to a "0" (on). Sometimes it's revered around too. You have to adhere and go by the newest FS spreadsheet.
So the above example would be simply ???? ???1 ???? to-> ???? ???0 ????
But, write down the entire old hex code, I then underline the changed character and make a note to what it was changed to. Yep, old fashioned paper and pencil works for me.
Pretty easy, I'd say getting your OBDII and computer setup and talking is much more the task.
#45
