I have a 89 F-250 with a 351w. When I go to start the engine it blows a little black smoke out the exhaust. Is it cause of old oil? I recently bought this truck and I use it around a farm. I dont know the miles because the dash cluster dose not work. It will only show the RPMs. Anything similar happen to anyone else?
It runs fine. It has trouble starting due to solenoid/relay or starter issues. But yes the check engine light is on. The wiring is a mess under the hood, but im really not concerned about that. Ultimately i have other plans for the 351. I was just curious if black smoke was particularly bad for the engine.
It dose run fine. Check engine light is on but thats because the wiring under the hood is a nightmare. Also because it was originally an automatic C6. Now it is a 5 speed ZF S5-42.
On most Fords checking fuel pressure is as simple as checking tire pressure. Screw on a gauge start it up turn it off & see if the pressure holds steady. If it does'nt something is leaking
You can also do a hard downshift engine brake test. If you downshift to ~3000 rpm and let the engine slow you down there should be no fuel injecting, so if it stumbles and pops and is not smooth, you have a leaking injector. In a downshift, it should be smooth as though the key was off.
The PCM doesn't control a C6 and wouldn't know you now have a 5 speed.
