4.0 SOHC upper oil pan gasket in truck replacement
UPDATE!! This is a NON-Issue for me, after a couple hours cleaning up and drying off the underside of the motor, a re-run showed a leak at the Oil Filter Mounting flange. After reading up on this part, apparently due to the immediate location of the Exhaust Manifold (Thanks Ford!) the O-rings internal to the unit dry and crack leading to significant leaks in some cases..... like mine...... With the drips going directly onto the catalytic converter and smoking a LOT, I'm surprised this was not a technical bulletin etc.
Super glad this is the issue even though the manifold will be tough remove, it should not prove to be any more difficult than the girdle.
daverdfw
02-03-2019 06:23 PM
scotttahoe
49
10-25-2013 12:02 PM
kellwhy66
02-04-2010 01:25 PM
