E4OD to ZF 5 Swap
E4OD to ZF 5 Swap
I have seen a lot of these posts to swap the trans in diesel forums but not so many in the gas forums. The swap into my 92 F150/351W, 4x4 seems like it will be possible but I have some questions.
The diesel forums mention a zf 5 from a diesel is needed, what are the options for me to use with my block can I use any zf 5 (5s-47) 4x4 that will mate to a small block Ford?
I am not sure of the parts I might need that go on the crankshaft underneath the flywheel. Right now the flexplate mounts directly to the back of the crank, there are no bushings or spacers but I think one might be needed for a manual setup. Any diagrams of the parts in this area?
You need a small block ZF5, as the bell housing differs between gas small block, gas big block, and diesel.
A ZF5 in a F150 may not be the best option. Read the linked thread.
https://www.ford-trucks.com/forums/1...nsmission.html
on
I've got a ZF in my F150. I converted it years ago from an E4OD. Here is a pic that helped me get started - this is a pic of everything you will need. Make note that you CAN NOT use a 4x2 version of the trans in your application, it must be a 4x4 trans.
BTW I've had 'em both and I prefer the ZF. The granny gear is really handy when trying to get a load moving, especially up a hill.
It looks like I am missing a 4x4 shifter from my list, I wasn't clear on that.
I got the brake and clutch assy this weekend for $20. Looks like I need to do some repairs where the master cylinder attaches to the clutch mechanism.
https://imgur.com/a/tTHYM
What is the part in the picture? This is what I originally posted about, not sure if I am missing it or don't need it.
Back story: I bought a 351W motor (92-96) from a junk yard, only asking that things be in good enough condition to rebuild the block. I have no idea what type of vehicle this came from or what trans was mated to it. When I bought the motor I remember someone mentioning something about this part, but not really sure of those details. When I removed the part, I wrote a note "insert into back end of crankshaft for use with a manual tranny"
I took the parts picture originally provided by jas88 and added labels to the parts, missing one part name. Let me know of any corrections. There are a few items missing from the picture:
Rear drive shaft
Pivot ball
Clutch Fork
Clutch pedal position switch
Slave cylinder
Transfer case shift linkage
(optional)
Trans wiring harness - you don't need this if you know how to re-wire the existing harness to work
Steering column cover
PRNDL blank cover
Rear drive shaft
Pivot ball
Clutch Fork
Slave cylinder
(optional)
PRNDL blank cover
on
The part missing a label on the right is the Separator Plate. It goes between the engine and transmission.
The E4OD ate all my money, and now I'm in an apartment which makes it a little harder to work on things. I'm sure the zf5 will be good for a while, the next thing to go is probably my rear end. It's probably sat idle 50% over the last 3 years, used to be my daily driver, want to get it back on the road.
Updated.
Parts needed for a small block ford E4OD to ZF 5 conversion.
If you have a 4x4 vehicle, you need a zf 5 from a 4x4 (that will have the proper output shaft for the transfer case).
See picture below, and note, there are a few items missing from the picture:
Rear drive shaft
Pivot ball
Clutch Fork
Slave cylinder
(optional)
PRNDL blank cover
Rear drive shaft
Pivot ball
Clutch Fork
Slave cylinder
(optional)
PRNDL blank cover
norconut
16
07-30-2011 11:36 AM
351M
06-26-2005 05:40 PM
