I got a stock Cleveland In a '79 F150, Or do I?
I have a stock, 1979 Ford f150 4x4 custom. It has a VIN tag that states it has a 351 motor. So I looked up 351's and my head split. is it a 351(M)odified? a 351(W)indsor? A 351(C)leveland?....holy mackeral.
So, I do my research and I strongly believe it is a 351CLEVELAND. It has 8 bolts in the valve head covers and the fuel pump has bolts into the engine block at 12 oclock and 6 oclock. But it is a 1979.
Door tag states it was ordered from the Seattle District from San Jose. Educate me.
351M.
351C production ended in 1974. In the US, the 351C was never in a truck other than a Ranchero.
Do you still have an emissions tag on one of the valve covers? Look for "engine family" and look for "400/351M" or just plain "351M".
Good news and bad news. Stock, it makes 139 HP. In other words, not enough power to hurt itself, as another member noted about the similarly hamstrung 360FE. This means you can probably rebuild it into a decent running 400, get twice the power and use the same amount of gas.
4th digit of the VIN is the engine code. 1977/79 F100/350 & 1978/79 Bronco: H = 351M
351C installed in 1970/74 Ford/Merc Passenger Cars/Ranchero only.
351W not available in F150/350 & Bronco until 1981. Has 6 valve cover bolts per side.
draglink
01-11-2006 08:35 PM
classicmetalman
05-14-2004 10:50 AM
