1954 f100 3 speed transmission replacement
Probably just a worn blocking ring, most of the better suppliers have them in stock. I'd rebuild it, probably less than $100 in parts. Not that difficult, plenty of info available. Still won't have syncro 1st gear but that's not much of a problem with old engines and low speed rear end ratios. A better alternative is finding an overdrive trans and hooking it up correctly, one of those will change your life. :-)
F100/250 223/292; Galaxie 223/289/352/390; Fairlane/Meteor 260/289.
Edit: 289 replaced 292 in 1963 Galaxie.
These same engines were used in all these 1964's except the Meteor ('rebadged' Fairlane) that was discontinued.
The 1949/62 3 speed manual (no syncro 1st gear) has two 2nd/3rd syncro blocker rings.
It has a 239 v8 in it. That's the point, I don't want to a big mod. I want to just bolt on a newer 3 speed with syncros. I just had power steering put in and had to change to a floor shifter. I don't know what happened but the transmission grinds going into 2nd gear. Blown syncro?
I think the first few years of the "303" all synchro 3 speed might have the old square trans to bell pattern. I am not sure that is the same pattern you have now. Bell depth is another consideration. But wait, there is another, more expensive solution:
Bellhousing, QuickTime, Flat head to Ford Toploader 4 speed
The 303 3 speed in the correct model will bolt right up where the top loader 4 speed would go.
Serving suggestion, but another imo better one was already made: T5
"I'm sorry, I must be an idiot." As my old boss used to say. But I digress.
Bellhousing, QuickTime, Y block to toploader, RM-8056
Ford changed the trans to bell pattern from square to rectangular ("Butterfly") in 1965, Thus, the early 303s had the square pattern. I do not know the pattern of the trans in question. If it is the square pattern, it will bolt up. If the input is too long, a spacer can be fab'd.
Early, SB six I think:
http://www.fordification.com/tech/images/3spd_303.jpg
Maybe what OP has:
http://www.vanpeltsales.com/FH_web/F...truck-3spd.jpg
Maybe what OP has:
fdeeptone
15
03-24-2014 06:20 PM
hellbilly1932
02-13-2012 11:35 AM
Bandito1961
01-21-2004 09:54 PM
