460 won’t idle
Old 11-23-2017, 05:52 PM
oldmanbergie's Avatar
oldmanbergie
oldmanbergie is offline
460 won’t idle
Just got my engine back from rebuilt shop everything new +30 flattop pistons crank 010/010 D3 heads everything new cam lifters valves springs timing chain you name it new. Got it into truck all new fluids filters spark plugs wires new rebuilt Holley 600.primed engine oil pumped up carb and started in one or two revulitions everything good oil pressure 75 psi no leaks. The problem won’t idle below 1500 /1800 rpms. Timing set 12 degrees btdc. Tried everything no vacuum leeks. Checked all the hoses good nothing unhooked. Runs like big vacuum leak ????? At my wits end. Any help appreciated thanks rick
Old 11-29-2017, 12:17 PM
cbakker's Avatar
cbakker
cbakker is offline
I’m not a carb guy but I’ll interject since nobody else has yet. What block are you using? What compression roughly?
Old 11-29-2017, 12:19 PM
cbakker's Avatar
cbakker
cbakker is offline
Also how much lift does the cam have?
Old 12-08-2017, 10:05 AM
oldmanbergie
it is a 1970 block bored 30 over has d3 heads mild cam compression ratio 10.0 -1. I swapped out the carb with holley 850 double pump and the engine ran / idled down great 500 /550 rpms. that 600 holley was bad. I wish I new what it is with that carb bad metering block ??? that carb was new and way out of warranty hate to junk it if it can be fixed
Old 12-12-2017, 08:25 AM
jas88's Avatar
jas88
jas88 is online now
Sounds like idle circuit plugged up perhaps? I call em Helleys cuz they are a helley-lot-of-trouble!
Scott Walter
04-24-2013 08:44 AM
Unegawahya
08-31-2010 01:24 PM
ATC Crazy
16
07-17-2010 12:57 AM
Bill Roach
33
03-25-2008 07:32 PM
austynn2001
08-10-2006 12:00 PM
Quick Reply: 460 won’t idle
