welder opinions
Millermatic 252 welder,,can get spool gun for aluminum separately .035 wire gauge for most ,, tank 75% - 25% for mild steel ,, tri mix tank for stainless steel ,,argon 100% tank for aluminum ,,good auto darken helmet,,the Millermatic 225 welder can do up to 1/2" steel an welds about anything you need ,,and get a welding blanket and some type of welding curtain or screen for outside welding to stop wind interference
Yesterday I picked up HF welding "blue flamed" helmet for the race shop so I don't have remember to bring the Miller Elite from my home shop.
For $39 it's a darn good value... fast reacting,, comfy, easy to adjust and head flip. I like the fact the grind/darkness **** is on the outside. Get one!
The last thing you want to do is spend a bunch of money, only to wish you had spent a little more later when you're ready to expand your welding skills (and you will). Get a proper MIG (i.e. gas shield) machine, as it can be set up as MIG or flux core. I would stay away from flux core for bodywork, as the heat input is not as controllable, and there's lots of spatter to clean up. If you're operating in the wind, just turn the gas flow up. Also, get a 220v machine. You can just dial down the voltage for sheet metal work. I do a lot of custom fabrication and body work (see my build thread for examples), and I've never seen a reason to spend thousands on a Miller or Lincoln. I've used both in welding school, but I've been using the snot out of my 220v Eastwood MIG 175 for about 6-7 years, and I couldn't be happier.
2: Yup
3: Yes, spend some money here. Especially if you're doing body work because you'll be doing hundreds of tack welds instead of one continuous bead. The cheaper helmets have a slower reaction time and will lead to pretty bad eye fatigue when you're starting and stopping the arc that many times.
4: Gas cost depends of cylinder size. I recommend spending more on a big bottle because you'll have to fill it less often, and it costs less per pound in the long run (it works on an exchange program like a propane tank).
5: Pulse is a feature you'll find on high-end MIG machines, and will be of little to no use to you. I use the pulse function on my TIG occasionally, but never MIG pulse. Most machines don't have that feature.
so 72 cf will last1 spool of wire? 1/2 a spool?
BTW: is there a standard length of wire on a spool?
the reason I asked here was because I have seen a cubic butload of pics that some of yall have done on your welds. plus... the welds would be on the same body panels so to speak, I duno if the guage has changed over the years or if that would matter much.
Finally: thanks for the info, I am now able to start to ask and think differently on some of this. normally I am a hands on person, especially after watching someone. this time its gona be read, youtube and just do it.
Fert
Fert
Fert
Fert
I bought my rig in '09 and I bought my gas bottle out right at that time as well --the gas cylinder is mine, I don't rent it.
The 80 cu. ft. cylinder was $150.00 dollars. The gas was $25.00. All together (in '09) the total cost of the filled cylinder, with tax, was $193.16.
....my Lincoln K520 welding cart will handle up to a 150 cu. ft. bottle.
HIO Silver. I also have one of those cheap harbor freight auto darkening helmets. I've owned it for a couple of years and had to stop using it because it doesn't get dark enough anymore.
I use a millermatic 210. If you're doing body work, you'll want solid core wire. You might need to turn up the gas some if welding outside, but the flux core wire is really messy with a lot of splatter.
#29
Best and most flexible welder on the market. High quality, and best warrantee.
Everlast 251. Yes, his voice is annoying, but his info is good.
https://www.youtube.com/watch?v=LPPgiwYZriQ
I have been watching some of his videos.
thanks for the info
Fert
#30
