1951 F-5 239 Exhaust Manifolds
Old 11-21-2017, 01:39 PM
jwhorsefolk
jwhorsefolk is offline
jwhorsefolk is starting off with a positive reputation.
I have been hanging a few more parts on the Big Gal's rebuilt 239, and have run into an issue with the exhaust manifolds. The engine builder thought I wanted headers, so he got rid of the originals, not that they were in great shape. I have a few sources for original manifold, but nobody knows about truck manifolds. The set I tried were stamped 8BA-9431 on the left side, and when I tried to mount them the the cross-over hits the engine mount frame horns. Does anyone have a photo or diagram of the correct exhaust manifolds and maybe a stamped number?
Old 11-21-2017, 03:15 PM
46fordtruck's Avatar
46fordtruck
46fordtruck is offline
46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.46fordtruck has a great reputation on FTE.
Moved to '48-'56 forum. Good luck, I hope you can figure it out.
Old 11-21-2017, 04:52 PM
jwhorsefolk
OK guys, I friend sent some info...
Old 11-21-2017, 05:39 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
The p/n's for what you want are 7RT-9430 (PS) and 7RT-9431 (DS).
What you posted is a Car exhaust system. They had different engine supports.
Old 11-21-2017, 05:48 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The OP lives in San Dimas CA where Early Ford Store is located. AFAIK, this is the only Ford obsolete parts store extant here in LA LA Land.
They have tons of used parts, so he should whiz over there and see if they have a pair of 1948/53 truck V8 flattie 7RT exhaust manifolds.
The 8BA-9431 left manifold he alluded to in post #1 is for a 1949/51 Ford V8 car.
earlyfordstore.com
Old 11-22-2017, 12:52 AM
52 4x4's Avatar
52 4x4
52 4x4 is offline
52 4x4 is gaining momentum as a positive member of FTE.52 4x4 is gaining momentum as a positive member of FTE.
21A-9431 (LH) will work on the the driver side, but the outlet is a bit smaller. Most likely the 21A-9430 will work on the passenger side, but haven't actually tried that one. - Bob
Old 11-22-2017, 11:02 AM
NumberDummy
21A-9430 Right & 21A-9431 Left .. Exhaust Manifolds / Obsolete
239 V8 1942/47 Commercial (1/2 ton truck) & 1942/48 Ford/Merc Passenger Cars.
kciv00
10-01-2014 09:19 PM
bread320i
04-30-2013 08:35 PM
fastphil
01-04-2013 10:26 AM
randycarmichael
04-22-2012 04:25 PM
Somessound
09-15-2007 02:42 PM
Quick Reply: 1951 F-5 239 Exhaust Manifolds
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
