2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Beyond standard gauges
Old 11-22-2017, 08:02 AM
Afrnd2all's Avatar
Afrnd2all
Afrnd2all is offline
'17 f-250 Xlt 4dr SCSB 6.7l 3.31. Are there additional gauges anyone out there would recommend to monitor engine performance? I've talked to some people around town who monitor Oil temp. Exhaust temp. Trans. temp. Just not sure what is important to keep an eye on while towing. Thanks,
Old 11-22-2017, 08:12 AM
Turbo Dog's Avatar
Turbo Dog
Turbo Dog is offline
Depends on how close you want to monitor the engine. While towing two important gauges for a diesel would be exhaust temp and transmission temp for an automatic. Then if you want to know how the engine is performing you could also watch the turbo boost pressure.
You can add these add individual gauges or buy a scan tool that can display many more readings.
Old 11-22-2017, 08:31 AM
nuctrooper's Avatar
nuctrooper
nuctrooper is offline
I would say no, there is nothing you need to monitor on the truck. It’ll run all day, do regens, etc without a driver input and with no change in operating pattern required.
IF you LIKE to monitor extra indications, there are a couple good options. No aftermarket sensors needed, just a reader to display what the truck already monitors. Some use a smartphone/BT OBDII adapter and can pull up all data. I like the edge CTS2, as it’s always available, because I like to watch extra info (not because I feel I need to)
Old 11-22-2017, 09:31 AM
Top_Speed1's Avatar
Top_Speed1
Top_Speed1 is offline
On my past trucks, we modified the engines and always monitored EGT's as the most important of gauges.
oh2sd
Modular V10 (6.8l)
11-01-2014 06:51 PM
FordTruckEnthusaist
07-19-2012 07:31 PM
got2befast
07-17-2010 07:10 AM
twg1966
06-25-2010 01:51 PM
hotshothauler
16
11-08-2005 10:35 AM
Quick Reply: Beyond standard gauges
