Race Truck Stance... Help!
Old 11-20-2017, 10:47 PM
VMPowerstroke's Avatar
VMPowerstroke
VMPowerstroke is offline
I want that low and wide look like a race truck with my leveled 2002 Ford F-350 SuperCrew Cab 2WD. What is the max wheel size and offset I can go? I’m getting street tires also because it’s not a work truck anymore. I was looking into rims and was thinking about getting 20x12’s with a -44 offset on 315/35/R20’s tires.
Old 11-21-2017, 06:23 AM
Whitey Ford's Avatar
Whitey Ford
Whitey Ford is offline
FTE-Spread The Knowledge
Good luck. We have 305’s but have seen 315’s without wheel well cutting. No sure on the wheels we still have stock. Spacers we got here:
https://www.motorsport-tech.com/specialss/truck/ford_s
(Talk to Lenny)
Please post some some pics when you get done. Not much on here about leveling, spacers, or tire sizes for 2wd 7.3’s.
Old 11-21-2017, 08:38 AM
lpzd's Avatar
lpzd
lpzd is offline
that put your wheel back spacing at 4.26" that leaves 7.7 inches from mounting flange to outside lip of wheel. with 4.34 inches of side wall .
I have no experience with that setup .
measure it up. I don't think the back side is going to be your issue , outside scrub radius would be my concern but that tire is only 28.68 inches calculated height so it may not be a issue.
(P.S. i hope you like turning rpm)
Jonnyuma
09-25-2017 06:24 PM
Kakejelly13
06-13-2017 12:51 AM
JJ3
04-24-2010 02:38 PM
turnrjr
19
03-03-2010 11:01 AM
NY-Ford-Lifer
2004 - 2008 F150
04-12-2004 01:31 PM
Quick Reply: Race Truck Stance... Help!
