Door glass divider removal
Old 11-20-2017, 07:01 PM
df85732's Avatar
df85732
df85732 is offline
df85732 is a name known to alldf85732 is a name known to alldf85732 is a name known to alldf85732 is a name known to alldf85732 is a name known to alldf85732 is a name known to all
Question Door glass divider removal
Have you ever tried that horseshoe ring puzzle where you try to get the ring free from two horseshoes welded together with chains? Well that's what this divider bar is doing to me. Driving me nuts! Getting ready to paint the doors and can not get it out. I'm ready....give me the easy answer. Thanks,
Old 11-20-2017, 07:43 PM
abe's Avatar
abe
abe is online now
abe has a superb reputationabe has a superb reputationabe has a superb reputationabe has a superb reputationabe has a superb reputationabe has a superb reputationabe has a superb reputationabe has a superb reputationabe has a superb reputationabe has a superb reputationabe has a superb reputation
Did you check the shop manual? I'm not sure if it's in there.
But, they do come out. You drop it down then you got to twist it and turn it. Just keep trying. It's not just 53 to 55 trucks either. I got a pair of used 61 to 66 doors to resell and I took the division bar out and it was a bear.
Now after you get it out and have the bar freshly painted black, I recommend you put masking tape or painters tape over the painted part so it doesn't get scratched going back in!
Good luck!
Old 11-20-2017, 07:57 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Old 11-20-2017, 09:35 PM
GoldCo's Avatar
GoldCo
GoldCo is online now
GoldCo is gaining momentum as a positive member of FTE.GoldCo is gaining momentum as a positive member of FTE.
bill, you got that same diagram handy for a '52 by chance?
Old 11-20-2017, 09:57 PM
Harrier's Avatar
Harrier
Harrier is offline
Harrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant futureHarrier has a brilliant future
Cut about a 2" section out of the door where the bar is and it will come right out.
I haven't removed mine yet. I was hoping to avoid that job, but I will really need to if I want to get felt in their properly.
Take pictures and give us the rundown of how it goes.
Old 11-20-2017, 10:14 PM
df85732's Avatar
df85732
df85732 is offline
I think I can get by with a 1 1/2" cut! Thanks for the advise Joe
So far just taking out all screws I find and it all loosens up. Those ****** handle springs are a PITA. One went flying. Know idea where it went. My biggest fear putting it all back without scratching my new bling
Old 11-20-2017, 10:15 PM
Doc's Avatar
Doc
Doc is offline
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
It's like working one of those puzzles at Cracker Barrel or somewhere like that. I did it a few years ago. Believe it or not, it WILL remove and go back without having to cut anything. Seems like I remember you have to get it completely horizontal and then bring it up or out or whatever.. Just keep trying different attempts and directions.
Old 11-21-2017, 06:48 AM
rio68's Avatar
rio68
rio68 is offline
rio68 is starting off with a positive reputation.
Just put mine back in...goes back in better than coming out...lol! Like to never have gotten them out but they did come out. I had to put more pressure on the front corner and may have bowed it a little...not enough to bend it just enough to clear the bottom corner. Always found when it gets to that point of utter frustration ...pack of cheese crackers and coke break helps....lol!
Old 11-21-2017, 06:49 AM
rio68's Avatar
rio68
rio68 is offline
Originally Posted by NumberDummy View Post
Bill, you got a 21464 LH side???
Old 11-21-2017, 07:27 AM
df85732's Avatar
df85732
df85732 is offline
Thanks Bill for the diagram. It sounds like there are no tricks, just finesse. So today is a new day. I plan to go into my shop with a new and refreshed attitude. Just like the Little Train that Could " I know I can, I know I can, I know I can...."
Old 11-21-2017, 07:38 AM
Silver54's Avatar
Silver54
Silver54 is offline
Silver54 has much to be proud ofSilver54 has much to be proud ofSilver54 has much to be proud ofSilver54 has much to be proud ofSilver54 has much to be proud ofSilver54 has much to be proud ofSilver54 has much to be proud ofSilver54 has much to be proud ofSilver54 has much to be proud of
Good luck Dave let us know how you make out
Old 11-21-2017, 11:02 AM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
petemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud of
I removed both of mine. You are right, it is like a Chinese puzzle. I was so relieved to get them out without damaging anything that I immediately forgot how I did it. I can only tell you that they do come out.
Old 11-21-2017, 01:15 PM
Dangeruss's Avatar
Dangeruss
Dangeruss is offline
Dangeruss is gaining momentum as a positive member of FTE.Dangeruss is gaining momentum as a positive member of FTE.
It took me a while to figure it out but I am able to get mine in and out fairly easy without too much of a headache. Lower the divider all the way down into the door and move the lower part all the way to the lower back edge of the door. Push the top part of divider into the very top corner of the door, up toward where the mirror attaches. When you think you have all the way up into that corner....you don't Keep rotating the divider bar on its axis and it will slide up in there enough to get the bottom of the divider bar to just slide out of the inspection hole. It is really tight and after you have paint on the door you will want to tape the divider bar and door to keep from scratching the paint.
Old 11-21-2017, 02:30 PM
Harrier's Avatar
Harrier
Harrier is offline
Or, just buy a plane ticket for Dangeruss to come out and do it for you. It might be worth the cost.
Old 11-21-2017, 03:11 PM
das54's Avatar
das54
das54 is offline
das54 has a very good reputation on FTE.das54 has a very good reputation on FTE.das54 has a very good reputation on FTE.
Is this any help?
Quick Reply: Door glass divider removal
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
