2001 F-350. AC is only blowing through the defrost vent
on
Vacuum leak.
When switching to 4wd, the ESOF hubs try to lock into place. If they leak (often do), they won't engage and the HVAC switches to defrost only.
With your hood up and engine off, turn the key to Run position and listed for the vacuum pump. It should run a bit then turn off. If it keeps running, it can never build vacuum.
You can also try to switch to a different vent position after the vacuum pump stops running. See if it works and listen if the pump goes crazy, indicating a leak.
Keep it in 2wd to eliminate extra factors
Let us know what you find
The rubber vacuum hose that runs from the front hubs to the nipple on the frame often rots away. Good place to start your search for a vacuum leak. You can replace the hose and maintain the ESOF system or remove the hose and cap off the nipples, but then you need to switch the hubs manually.
Dude-Ford
34
01-10-2023 12:08 PM
DGMFORD
1999 to 2016 Super Duty
17
01-07-2010 12:31 AM
