When do you plug in your diesel?
Ok, so I had to go look.
In the diesel supplement it states: "An engine block heater is recommended at temperatures below –10°F (–23°C)."
In the owners manual it states something slightly different: "Note: The heater is most effective when outdoor temperatures are below 0°F(-18°C)."
With regards to how long to run it:
"The heater uses 0.4 to 1.0 kilowatt-hours
of energy per hour of use. The system does
not have a thermostat. It achieves
maximum temperature after
approximately three hours of operation.
Using the heater longer than three hours
does not improve system performance and
unnecessarily uses electricity."
Check your manual but I believe that the 6.7 does not require being plugged in above -10F, however, you may want to plug it in above that temperature since the truck will take less time to warm up. I do this about 1-1.5 hrs before I leave the house and I get heat in the cab sooner. Most mornings I have a short commute to work so the engine gets to normal operating temperature sooner.
I'm pretty sure Ford has a specified temperature range but as others have stated it's really a point of keeping you warm for that ride to work in the morning even with the supplemental Electric interior heater. The only thing I can tell you I've had the truck start as low as minus 21 below standing temperature not wind chill with no problem after a good night 16 hour soak just keep your batteries up I changed them too AGM batteries in my 16. Believe me I wish I could have plugged it in but sometimes job sites don't even have power other than a generator and the contractor isn't going to allow you to plug your truck in LOL also anti gel is very important at those temperatures I don't care what brand you use just use one you'll never have an issue with jelling fuel filters. Also it becomes quite an argument around here I recommend a full synthetic oil you'll never have an issue with a slow turn over 5w 40 take care
I live in Wisconsin and we see plenty of cold weather. I've never plugged either of my 6.7L trucks in and have never had an issue. Does't mean that I am correct, just stating what I do. Been driving a 6.7L for almost 6 years now. Drive it every day. Takes a while to warm up but starts easy, even when really cold.
Bruce...
Bruce...
I plug in below 20. I only do this to get heat sooner, as I don't get heat between my house and work if it isn't plugged in.
That said, I've started my truck many times at -20 and had no issues at all. I recall reading an article that talked about the 6.7's being tested and designed to start down to -40 without a block heater, though it is recommended as others noted.
Last year I was spoiled as I had heated garage. This year, once again, I am parking outside.
Like js139 - I try to plug I with the temps are below +20F. The State of Alaska recommends this temp - even for gassers too. Supposedly it helps with fuel economy and with emissions. I wish I had a dependable timer, so most of the time it's plugged in right before I go to sleep - so 8 hours. Which I did last night. Now it was warm this morning at +13F and after a few minutes of a remote start idle time it was nice and toasty when I got inside. However it wasn't that way the other days I didn't plug in at +13F (or colder).
FWIW, while the motor starts in the sub zero cold, I like the sound of the way it starts better if I plug it in. Add the benefit of not scraping the frost off the windows in the morning and getting into a warm cab and for me it's worth it to plug in.
My truck is plugged in all night every night if it's below 40. I hate getting in a freezing cold truck. If I'm somewhere it can't be plugged in its not a concern, but if I can plug it in I will. I also drop the baby off at daycare in the morning and he likes a warm truck too. But my routine started long before him. I'l pay the electric bill, it really doesn't make a big difference.
The temps get in the forties, my truck is plugged in. I like the fact the heater gets warm right away.
Yeah I know 0(ish) is the official time to plug in, but I too like to do it anytime that temp starts dropping below 38 to 40 and I know I need the truck.
I went a little over board and setup thermostat to an app that controls when my heater comes on. This way if it is 4:00am and I need to drive at 7:00, and the temp is below 38 the heater will come on. Of course now I just need to find an app that will actually plug the truck it by itself.
Personally, I ordered by 6.7L without the engine block heater...it's parked in the garage, so even when it's 0 outside, it's still about 50-55 in the truck.
What js139 said... The 6.7s start down to -40F (which is also -40C) and there are some youtube videos with starts colder than that. I have gotten the wait to shift with a 10 second or so countdown at around -20F, if not plugged in. Obviously, if you remote start for a few minutes before you make it to the truck, you'd never see a countdown. Oh the "Please wait" isn't a suggestion, it won't let you shift until it's ready to let you shift.
