15 F350 SRW to DRW - Ford Truck Enthusiasts Forums
15 F350 SRW to DRW
Old 11-20-2017, 01:12 AM
King92
King92 is offline
King92 is starting off with a positive reputation.
15 F350 SRW to DRW
So I bought a truck last year befor I knew anything there is to know about trucks. Now I知 at a point where I need to haul more weight than I can with my 15 F350 SRW. Is the frame the same in both SRW and DRW? Will a DRW 10 bolt axel bolt in place?
I understand gearing situations and having to do both front and back axle. Just want to see if they bolt up and what I値l need before I dive in.
Old 11-20-2017, 03:21 AM
90pioneer
90pioneer is offline
90pioneer is starting off with a positive reputation.
How much weight do you need to haul? You'll be amazed at what the SRW can handle.
Old 11-20-2017, 05:58 AM
Just Strokin
Just Strokin is online now
Just Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud of
I would go check out the towing guide and then compare the weights you want to haul verses the SRW and the DRW. As stated by 90pioneer, you might not need to try to update.
RV & Trailer Towing Guides | fleet.ford.com
Old 11-20-2017, 07:17 AM
99150's Avatar
99150
99150 is online now
99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation99150 has a superb reputation
The difference in frame would be if the 350/450 is a cab and chassis vs pickup. The frame on the c/c is narrower than a 350/450 pickup.
The 350 dually uses the Dana 80 rear axle, which has an 8 bold pattern. The front is the same Dana 60 that is in your 350, but has wheel spacers to set the front wheels at the correct width to match up tp the rears. This set up *should* bolt right up under your 350, unless the rear came out of a cab and chassis truck. The Dana 80 will carry all the weight you can *legally* carry in your 350 and you would not need to go to the 10 bolt pattern, but would need to change out all wheels to dually type wheels. Good luck in your endeavor.
Personally, for the cost involved, I would check out trading vehicles also. But that might be just my idea.
Old 11-20-2017, 07:53 AM
bobv60
bobv60 is online now
bobv60 has a very good reputation on FTE.bobv60 has a very good reputation on FTE.bobv60 has a very good reputation on FTE.
I will add my opinion.
first, a two year old truck in good condition should still be worth a decent amount. Yes, you will lose a lot trading it in, but how about selling it yourself? You might even be able to find someone with a dually who want to downsize.
second, all the money and time you put into making it a dually will make the truck worth less money and be harder to sell later. People dont want a truck that has that much of a modification.
Some will argure that you cant "legally" haul any more becase the door sticker will still show its a SRW.
In the long run I believe you will be money ahead to just sell what you have and buy a dually. It wouldnt cost you anything to post it for sale an sites like Craigslist and see what happens.
If you haven't driven a 450 or a 350 DRW with the wide front axle you need to. They turn MUCH sharper than a SRW truck. I can U turn my F450 crew cab long box on a two lane road without backing up.
Old 11-20-2017, 10:09 AM
King92
King92 is offline
Lots of weight
I知 in the ball park of towing 25k with about 6-7k hitch weight.
Old 11-20-2017, 10:28 AM
djousma
djousma is offline
djousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to behold
You are definitely into the DRW field then. As Bob mentioned, I think you will be better off trading/selling, and buying a DRW F350/F450.
Old 11-20-2017, 11:30 AM
King92
King92 is offline
New truck ;(
The issues I知 having with doing that is well my credit it **** and I have 150k put on the truck in the past year so I would get nothing for it. they would want a payment of around $1800- 2100 a month for a DRW. So if I take all that money and sink in to what I知 stuck with. All I want to do is put 10 bolt DRW with better gearing both front and rear axles.
Do do I need to do gearing on my transfer case?
Do I need to change transmission?
Do I need to change drive shafts?
Can I find a manual trans anymore for this year of truck?
Old 11-20-2017, 01:25 PM
djousma
djousma is offline
Gotcha King. Hopefully someone more knowlegable will swing by and answer your questions.
Old 11-20-2017, 01:28 PM
bobv60
The f350 Drw trucks are 8 bolt st 200mm bolt circle. A quick list is 7 wheels and tires, dually rear end (DANA 80), front wheel hub extention, a dually bed or fenders, or a dually flatbed, new gears for the front ( with that much weight I would go 4.10 or 4.30 gears). Transmission and transfer case will not need to be changed
then a lot of unknowns. Like parking brake cables, rear driveshaft modifications, heaveier front springs.
I am sure there is more. You will probably be on your own for most of this, there probably hasn't been a lot of this modification done.
Old 11-20-2017, 02:59 PM
King92
King92 is offline
King lol sounds like I知 cocky but it痴 my dogs name.
Old 11-20-2017, 03:06 PM
King92
King92 is offline
8 bolt to 10 bolt upgrade
i chatted with a friend that ordered is F350 with 10 bolt axles. He said said it was a 2015 F350 ( not cab and chassi ) with a 450 suspension under it. I wander if that a factory order thing only
Old 11-20-2017, 03:23 PM
js139
js139 is offline
js139 is starting off with a positive reputation.
I have a buddy that did this. He has a 350 with 350 axles, but has the turning radius of the 450. Great way to go, but I believe it is only a factory order option (which he did).
Old 11-20-2017, 04:07 PM
nuctrooper
nuctrooper is online now
nuctrooper has a good reputation on FTE.nuctrooper has a good reputation on FTE.
No transfer case or tranny change needed - same from the 250 to the 550
Drive shaft should be the same, but the U-joint size would need to be matched. May require a new yoke on the axle pinion (depends on the new axle year and source)
Manual tranny - no way. Unless you want to go back to the 6.0.
Regarding 8 or 10 bolt axles. I'd get whatever you can source from a wrecked truck. If you can find a wide track front go for it, otherwise the 10 bolt is just going to cost you more money and limit your options. Less wheel options (and more expensive), less tire choices, less donor vehicles. A lot of patience may net you the running gear from a wrecked 450 pickup, but it may be a LOT of patience. Also, remember it needs to be a pickup, not a C&C unless you can do some welding and metal fab. Much slimmer pickings.
As far as the bed - the dually fenders simply bolt to the bed. Drill come holes, touch up paint and bolt up donor fenders.
Have fun!
Old 11-20-2017, 08:57 PM
texinwa
texinwa is offline
texinwa is starting off with a positive reputation.
I've got a a pair of F350 dually axles with 4.30 ratio from a 2015 for cheap. Don't know your location.
Quick Reply: 15 F350 SRW to DRW
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
